Logarithm
7 years 11 months ago #120328 by rodw
Replied by rodw on topic Logarithm
Hmm, log() is not included in rtapi_math.h github.com/LinuxCNC/linuxcnc/blob/master/src/rtapi/rtapi_math.h
I would search for the C code in the GCC compiler for the log function and add it to my component.
Or try and add it to the header file....
7 years 11 months ago #120329 by andypugh
Replied by andypugh on topic Logarithm
I don't see a log function in rtapi_math.
There is a simple (recursive) log2() function here:
www.geeksforgeeks.org/program-to-compute-log-n/
And log10(N) = log2(N)/log2(10)
I just noticed that the log2 above is calculated as an integer, so might not give the accuracy you need.
Why do you need a logarithm in HAL? Maybe there is another way?
7 years 11 months ago #120330 by yeepah
Replied by yeepah on topic Logarithm
thanks for your answers
I will work on that
I using linuxcnc to drive a reprap. I'm following and adapting the work of this guy.
www.anderswallin.net/2012/12/temperature-pid-control-part-deux/
Using hal encoder with NTC resistor and ne555 chip to control PID and pwmgen.
Thermistor change a frequency read by linuxcnc.....regulate extruder and hotbed temperature
To calcul the temperature with the frequency I need a log
I will work on the direction you give. And come back with the result
thanks
7 years 11 months ago #120331 by andypugh
LinuxCNC 2.8 (development version) includes this:
linuxcnc.org/docs/devel/html/man/man1/thermistor.1.html
And also this:
linuxcnc.org/docs/devel/html/man/man9/max31855.9.html
But for 2.7 it might be simplest to use this:
linuxcnc.org/docs/devel/html/man/man9/lincurve.9.html
7 years 11 months ago #120335 by rodw
Well thats actually quite strange. thermistor.comp use the log() function. I wonder why and even if it compiles?
github.com/LinuxCNC/linuxcnc/blob/master...omps/thermistor.comp .
7 years 11 months ago #120336 by andypugh
The thermistor comp runs in userspace.
Time to create page: 0.157 seconds
