looking for an elegant way to address tool pockets
- Shu
15 Dec 2018 15:50 #122455
by Shu
looking for an elegant way to address tool pockets was created by Shu
Machine has an ATC with a magazine rack. Tool pockets are not all in line and do not have the same z height. I do have all positions of the pockets. What would be an elegant way to map the tool change position to the arbitrary pocket location?
My first idea was to have the pocket positions stored in a .hal file like this:
And write a atc_rack_change.ngc subroutine remapped to M6 like this:
Which isn't working as the #1 variable in the change_position_ variable is not parsed. Any better ideas?
I haven't tried putting the #1 in brackets. Will try that.
[CHANGE_POSITION_1]
X = 3391
Y = 1084
Z = -158.7
[CHANGE_POSITION_2]
X = 3391
Y = 980
Z = -158.7
[CHANGE_POSITION_3]
X = 3057
Y = 882.6
Z = -50.5And write a atc_rack_change.ngc subroutine remapped to M6 like this:
; #1 is current pocket number
o100 if [EXISTS[#<_ini[change_position_#1]x>]]
G53 g1 Z0 F30000
G53 g0 X [#<_ini[change_position_#1]x>]
G53 g0 Y [#<_ini[change_position_#1]y>]
(...)Which isn't working as the #1 variable in the change_position_ variable is not parsed. Any better ideas?
- Thank you received: 4658
16 Dec 2018 18:47 #122497
Replied by andypugh on topic looking for an elegant way to address tool pockets
How many tools?
You might have to use the unsatisfying
Which probably isn't _too_ tedious with copy and paste...
O100 IF [#1 EQ 1]
G53 G0 X[#<_ini[change_position_1]X>]
G53 G0 Y[#<_ini[change_position_1]Y>]
O100 ELSEIF [#1 EQ 2]
G53 G0 X[#<_ini[change_position_2]X>]
G53 G0 Y[#<_ini[change_position_2]Y>]
O100 ELSEIF....Which probably isn't _too_ tedious with copy and paste...
The following user(s) said Thank You: Shu
- Shu
17 Dec 2018 13:05 #122531
by Shu
Replied by Shu on topic looking for an elegant way to address tool pockets
Thanks, Andy. That looks like a solid solution!
Right now the machine has 7 pockets, in the end it will be 35. I might migrate to a bash script for the subroutine to compact it.
- aluplastvz
- Thank you received: 9
19 Apr 2020 10:14 #164644
by aluplastvz
Replied by aluplastvz on topic looking for an elegant way to address tool pockets
Hello Shu
Have you done ATC for 34 tools I have a problem with a machine that has 24 tools, do you have a solution
thank you very much
thank you very much
Time to create page: 0.601 seconds
