gearchange
5 years 9 months ago #196508 by andypugh
Replied by andypugh on topic gearchange
If you want to start easy, then a PyVCP box to enter the gear number in would be a good starting point.
Possibly a ComboBox to drop down the nominal speed of the selected gear, as I imagine that is how it is labelled on the machine?
5 years 9 months ago #196512 by anfänger
Replied by anfänger on topic gearchange
On the machine the gears are labelled with the nominal gear.
2240/1400
800/500
1120/710
1600/1000
560/355
200/125
280/180
400/250
140/80
50/31,5
71/45
100/63
which if those pairs I run can I change with an Mcode while spindle is running but not cutting.
Yea combox is probably the way to start
5 years 9 months ago #196527 by db1981
Replied by db1981 on topic gearchange
in case you are talking about your NEF480.
Pay attention with using an VFD on this Motor, i already burned an NEF Motor....
This Motor is only Iso Class B (evtl. E) and not build for use with VFDs. When using with lower RPMs there will be to much thermal stress for the windings, also the electrical insulation is not enough for todays VFDs. PWM and generated "Sinus" Output will produce µs Spikes of 800V or above.
Also with low rpms the gearbox lubrication will be insufficent.
Usable range for this motor will only be between 40-50Hz (60Hz if you have trust in the gearbox bearings.)
ps "ist das die blaue NEF aus Kirchen im WW?"
5 years 9 months ago - 5 years 9 months ago #196528 by anfänger
HI,
Yes I am talking about my NEF480 and it is the one from Kirchen. Do you know this machine?
I thought of using it from 35hz to 50hz. I know the oil pump is directly on the main shaft. I don’t know what the Punk thinks of 60Hz (1740 instead of 1450 rpm) But 40 to 56hz usage would cover almost all speeds.
How did you solve the Gearbox or are you using the VFD just as a soft start?
Last edit: 5 years 9 months ago by anfänger.
5 years 9 months ago #196531 by db1981
I consider to take a look at this machine because it was only 10km away from me...
But then i made the wrong decision and got a douple pack with nef 280 and nef 480.
i will retrofit the 280. The 480 was ok from the bed and the rest but at home i got a shock after a deeper lock :-( .
For the Gearbox and vfd i would write a specific component, like i did before for other retrofits.
5 years 9 months ago #196534 by anfänger
Oh that looks nasty, sorry for that.
Mine was a workhorse a bit neglected but not really mistreated. (They bypassed the limit Switches and crashed, so there are some nasty marks on the chuck and sled ). The Gearbox looks much better than yours. I negotiated a bit on the price and they drove it over to me. So far no really bad surprises.
I never programmed a comp just some small bash and python scripts to get my Chiron running.
I will start easy and maybe later get more fancy hoping the motor survives. I it dies I guess I am in trouble.
Time to create page: 1.834 seconds
