pid tuning Estun servo motor
- jlviloria
- Thank you received: 9
01 Apr 2019 13:44 #130113
by jlviloria
pid tuning Estun servo motor was created by jlviloria
Greetings, I'm in a conversion, I'm in the PID tunig phase, I have the default configuration. everything in zero. I put any value from 1 to 10 in P. but the engine moves it to a position and when it stops it remains with a vibration and generating a buzz.
The machine moves the two axes.
I have converted two machines of equal size. It is the first time I use ESTUN servomotor. the first two have used the original servos siemens. and I have started the PID tunig in the same way. which John advises, go up P until stability is lost and then return. but never generated that vibration and that buzz.
The servo motor is EMG-50AP22, 5kw, 2000rpm, 28A, 23.9Nm, AC200V.
the driver = PRONET-E-50A.
Any suggestion is welcome.
Jorge
Jorge
- pl7i92
- Thank you received: 359
02 Apr 2019 01:04 #130138
by pl7i92
Replied by pl7i92 on topic pid tuning Estun servo motor
the pronet may have a external preenable pin to set off the buzz
- Thank you received: 4658
03 Apr 2019 11:07 #130207
Replied by andypugh on topic pid tuning Estun servo motor
Try P < 1.
Try 0.1, for example, or even 0.01.
You might be able to kill the buzz with a _tiny_ amount of D. Or it might make it worse.
Time to create page: 0.120 seconds
