Master branch gantry Mesa 7i96
7 years 6 months ago #130450 by ikkuh
(moved from wrong category)
Thanks @rodw for your great example at forum.linuxcnc.org/47-hal-examples/34072...ranch-gantry-example
You helped me a lot when I was using the cheap Chines Bob and a gantry. Now I am using a Mesa 7i96 and I can not get it to work again. I want a functioning gantry for my Y axes, I had it working with the parallel Bob's.
I finally got the limit and home switches working, I had to invert them and it took me a long time to figure out that I can not use the
-not
construct in the hal file, I have to use
_not
for the 7i96.
But I can not get the gantry to work with both Y motors working as they should. I can see in the hallmonitor that three signals are generated, I seem to miss the fourth signal for the second Y motor.
Can you please take a look and tell me what I am doing wrong? Would be really appreciated :)
(my git repo: git.cnckloon.nl/CNCZone/Mesa_2019 )
7i96.hal
# ####################################### # # HAL file for HostMot2 with 3 steppers # # Derived from Ted Hyde's original hm2-servo config # # Based up work and discussion with Seb & Peter & Jeff # GNU license references - insert here. www.linuxcnc.org # # # ######################################## # Firmware files are in /lib/firmware/hm2/7i43/ # Must symlink the hostmot2 firmware directory of sanbox to # /lib/firmware before running EMC2... # sudo ln -s $HOME/emc2-sandbox/src/hal/drivers/mesa-hostmot2/firmware /lib/firmware/hm2 # # See also: # <http://www.linuxcnc.org/docs/devel/html/man/man9/hostmot2.9.html#config%20modparam> # and http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl?HostMot2 # # ##################################################################### # ################################### # Core EMC/HAL Loads # ################################### # kinematics loadrt [KINS]KINEMATICS # motion controller, get name and thread periods from ini file loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS # hostmot2 driver loadrt hostmot2 # load low-level driver loadrt [HOSTMOT2](DRIVER) config=[HOSTMOT2](CONFIG) # load estop latch component loadrt estop_latch ####https://forum.linuxcnc.org/49-basic-configuration/33867-how-to-connect-home-switches-for-dual-motor-on-3-axis-machine-2-8-pre-master#104933 loadrt stepgen step_type=0,0,0,0 # ################################################ # THREADS # ################################################ addf hm2_[HOSTMOT2](BOARD).0.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread # revel in the free time here from not having to run PID addf hm2_[HOSTMOT2](BOARD).0.write servo-thread addf estop-latch.0 servo-thread # --- MAX-X --- #net max-x <= hm2_7i96.0.gpio.010.in # --- ESTOP --- net estop-ext <= hm2_7i96.0.gpio.010.in net estop-out <= iocontrol.0.user-enable-out net home-x <= hm2_7i96.0.gpio.000.in_not net home-yR <= hm2_7i96.0.gpio.001.in_not net home-yL <= hm2_7i96.0.gpio.002.in_not net home-z <= hm2_7i96.0.gpio.003.in_not #probe #net probe-in => motion.probe-input #net probe-in <= hm2_7i96.0.gpio.009.in # --- GMoccapy tool probe net probe motion.probe-input <= hm2_7i96.0.gpio.009.in # ###################################################### # Axis-of-motion Specific Configs (not the GUI) # ###################################################### # ################ # X [0] Axis # ################ # axis enable chain newsig emcmot.00.enable bit sets emcmot.00.enable FALSE net emcmot.00.enable <= joint.0.amp-enable-out net emcmot.00.enable => hm2_[HOSTMOT2](BOARD).0.stepgen.00.enable # position command and feedback net emcmot.00.pos-cmd <= joint.0.motor-pos-cmd net emcmot.00.pos-cmd => hm2_[HOSTMOT2](BOARD).0.stepgen.00.position-cmd net motor.00.pos-fb <= hm2_[HOSTMOT2](BOARD).0.stepgen.00.position-fb net motor.00.pos-fb => joint.0.motor-pos-fb # timing parameters setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.dirsetup [JOINT_0]DIRSETUP setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.dirhold [JOINT_0]DIRHOLD setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.steplen [JOINT_0]STEPLEN setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.stepspace [JOINT_0]STEPSPACE setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.position-scale [JOINT_0]SCALE setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.maxvel [JOINT_0]STEPGEN_MAX_VEL setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.maxaccel [JOINT_0]STEPGEN_MAX_ACC setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.step_type 0 # ################ # Yr [1] Axis # ################ # axis enable chain newsig emcmot.01.enable bit sets emcmot.01.enable FALSE net emcmot.01.enable <= joint.1.amp-enable-out net emcmot.01.enable => hm2_[HOSTMOT2](BOARD).0.stepgen.01.enable # position command and feedback net emcmot.01.pos-cmd <= joint.1.motor-pos-cmd net emcmot.01.pos-cmd => hm2_[HOSTMOT2](BOARD).0.stepgen.01.position-cmd net motor.01.pos-fb <= hm2_[HOSTMOT2](BOARD).0.stepgen.01.position-fb net motor.01.pos-fb => joint.1.motor-pos-fb # timing parameters setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.dirsetup [JOINT_1]DIRSETUP setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.dirhold [JOINT_1]DIRHOLD setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.steplen [JOINT_1]STEPLEN setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.stepspace [JOINT_1]STEPSPACE setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.position-scale [JOINT_1]SCALE setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.maxvel [JOINT_1]STEPGEN_MAX_VEL setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.maxaccel [JOINT_1]STEPGEN_MAX_ACC setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.step_type 0 # ################ # Yl [2] Axis # ################ # axis enable chain newsig emcmot.02.enable bit sets emcmot.02.enable FALSE net emcmot.02.enable <= joint.2.amp-enable-out net emcmot.02.enable => hm2_[HOSTMOT2](BOARD).0.stepgen.02.enable # position command and feedback net emcmot.02.pos-cmd <= joint.2.motor-pos-cmd net emcmot.02.pos-cmd => hm2_[HOSTMOT2](BOARD).0.stepgen.02.position-cmd net motor.02.pos-fb <= hm2_[HOSTMOT2](BOARD).0.stepgen.02.position-fb net motor.02.pos-fb => joint.2.motor-pos-fb # timing parameters setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.dirsetup [JOINT_1]DIRSETUP setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.dirhold [JOINT_1]DIRHOLD setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.steplen [JOINT_1]STEPLEN setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.stepspace [JOINT_1]STEPSPACE setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.position-scale [JOINT_1]SCALE setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.maxvel [JOINT_1]STEPGEN_MAX_VEL setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.maxaccel [JOINT_1]STEPGEN_MAX_ACC setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.step_type 0 # ################ # Z [2] Axis # ################ # axis enable chain newsig emcmot.03.enable bit sets emcmot.03.enable FALSE net emcmot.03.enable <= joint.3.amp-enable-out net emcmot.03.enable => hm2_[HOSTMOT2](BOARD).0.stepgen.03.enable # position command and feedback net emcmot.03.pos-cmd <= joint.3.motor-pos-cmd net emcmot.03.pos-cmd => hm2_[HOSTMOT2](BOARD).0.stepgen.03.position-cmd net motor.03.pos-fb <= hm2_[HOSTMOT2](BOARD).0.stepgen.03.position-fb net motor.03.pos-fb => joint.3.motor-pos-fb # timing parameters setp hm2_[HOSTMOT2](BOARD).0.stepgen.03.dirsetup [JOINT_3]DIRSETUP setp hm2_[HOSTMOT2](BOARD).0.stepgen.03.dirhold [JOINT_3]DIRHOLD setp hm2_[HOSTMOT2](BOARD).0.stepgen.03.steplen [JOINT_3]STEPLEN setp hm2_[HOSTMOT2](BOARD).0.stepgen.03.stepspace [JOINT_3]STEPSPACE setp hm2_[HOSTMOT2](BOARD).0.stepgen.03.position-scale [JOINT_3]SCALE setp hm2_[HOSTMOT2](BOARD).0.stepgen.03.maxvel [JOINT_3]STEPGEN_MAX_VEL setp hm2_[HOSTMOT2](BOARD).0.stepgen.03.maxaccel [JOINT_3]STEPGEN_MAX_ACC setp hm2_[HOSTMOT2](BOARD).0.stepgen.03.step_type 0 # # The Mesa AnyIO output pins can be in open-drain mode (drive low, float # high) or push/pull mode (drive low, drive high). # # When a logical output is 1 in open-drain mode, the FPGA lets the pin # float and it gets pulled high to +5V via a 10K resistor. # # When a logical output is 1 in push/pull mode, the FPGA pushes the pin # high but only to +3.3V. This is problematic on some kinds of inputs. # #setp hm2_[HOSTMOT2](BOARD).0.gpio.048.is_opendrain 1 #setp hm2_[HOSTMOT2](BOARD).0.gpio.049.is_opendrain 1 #setp hm2_[HOSTMOT2](BOARD).0.gpio.054.is_opendrain 1 #setp hm2_[HOSTMOT2](BOARD).0.gpio.055.is_opendrain 1 #setp hm2_[HOSTMOT2](BOARD).0.gpio.060.is_opendrain 1 #setp hm2_[HOSTMOT2](BOARD).0.gpio.061.is_opendrain 1 # ################################################## # Standard I/O Block - EStop, Etc # ################################################## # A basic estop loop that only includes the hostmot watchdog. net user-enable iocontrol.0.user-request-enable => estop-latch.0.reset net enable-latch estop-latch.0.ok-out => iocontrol.0.emc-enable-in net watchdog hm2_[HOSTMOT2](BOARD).0.watchdog.has_bit => estop-latch.0.fault-in # create signals for tool loading loopback net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared net tool-change-loop iocontrol.0.tool-change => iocontrol.0.tool-changed
7i96.ini
[EMC] # The version string for this INI file. VERSION = 1.1 # Name of machine, for use with display, etc. MACHINE = 7i96 Ton CNC # Debug level, 0 means no messages. See src/emc/nml_int/emcglb.h for others #DEBUG = 0x00000003 #DEBUG = 0x00000007 DEBUG = 0 [DISPLAY] # Name of display program, e.g., tklinuxcnc #DISPLAY = tklinuxcnc DISPLAY = gmoccapy # Cycle time, in seconds, that display will sleep between polls CYCLE_TIME = 0.0500 # Path to help file HELP_FILE = tklinuxcnc.txt # Initial display setting for position, RELATIVE or MACHINE POSITION_OFFSET = RELATIVE # Initial display setting for position, COMMANDED or ACTUAL POSITION_FEEDBACK = ACTUAL # Highest value that will be allowed for feed override, 1.0 = 100% MAX_FEED_OVERRIDE = 1.5 # Prefix to be used PROGRAM_PREFIX = /home/ton/linuxcnc/nc_files # Introductory graphic INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 [FILTER] PROGRAM_EXTENSION = .png,.gif,.jpg Grayscale Depth Image PROGRAM_EXTENSION = .py Python Script png = image-to-gcode gif = image-to-gcode jpg = image-to-gcode py = python [RS274NGC] # File containing interpreter variables PARAMETER_FILE = 7i96.var [EMCMOT] EMCMOT = motmod # Timeout for comm to emcmot, in seconds COMM_TIMEOUT = 1.0 # Servo task period, in nanoseconds SERVO_PERIOD = 1000000 [TASK] # Name of task controller program, e.g., milltask TASK = milltask # Cycle time, in seconds, that task controller will sleep between polls CYCLE_TIME = 0.010 [HAL] # The run script first uses halcmd to execute any HALFILE # files, and then to execute any individual HALCMD commands. # list of hal config files to run through halcmd # files are executed in the order in which they appear HALFILE = 7i96.hal # list of halcmd commands to execute # commands are executed in the order in which they appear #HALCMD = save neta [HALUI] #No Content [TRAJ] COORDINATES = X Y Z #HOME = 0 0 0 LINEAR_UNITS = mm ANGULAR_UNITS = degree [EMCIO] # Name of IO controller program, e.g., io EMCIO = io # cycle time, in seconds CYCLE_TIME = 0.100 # tool table file TOOL_TABLE = tool.tbl [KINS] JOINTS = 4 KINEMATICS = trivkins coordinates=XYYZ [AXIS_X] MIN_LIMIT = -10.0 MAX_LIMIT = 10.0 MAX_VELOCITY = 10 MAX_ACCELERATION = 20 [JOINT_0] # X # Step timing is 40 us steplen + 40 us stepspace # That gives 80 us step period = 12.5 KHz step freq # # Bah, even software stepping can handle that, hm2 doesnt buy you much with # such slow steppers. # # Scale is 200 steps/rev * 5 revs/inch = 1000 steps/inch # # This gives a maxvel of 12.5/1 = 12.5 ips # TYPE = LINEAR MAX_VELOCITY = 10 MAX_ACCELERATION = 20 # Set Stepgen max 20% higher than the axis STEPGEN_MAX_VEL = 12 STEPGEN_MAX_ACC = 24 BACKLASH = 0.000 # scale is 200 steps/rev * 5 revs/inch SCALE = 1000 MIN_LIMIT = -10.0 MAX_LIMIT = 10.0 FERROR = 0.050 MIN_FERROR = 0.005 #HOME = 0.000 #HOME_OFFSET = 0.10 #HOME_SEARCH_VEL = 0.10 #HOME_LATCH_VEL = -0.01 #HOME_USE_INDEX = YES #HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 1 # these are in nanoseconds DIRSETUP = 200 DIRHOLD = 200 STEPLEN = 40000 STEPSPACE = 40000 [AXIS_Y] MIN_LIMIT = -10.0 MAX_LIMIT = 10.0 MAX_VELOCITY = 10 MAX_ACCELERATION = 20 [JOINT_1] ## Y TYPE = LINEAR MAX_VELOCITY = 10 MAX_ACCELERATION = 20 # Set Stepgen max 20% higher than the axis STEPGEN_MAX_VEL = 12 STEPGEN_MAX_ACC = 24 BACKLASH = 0.000 SCALE = 1000 MIN_LIMIT = -10.0 MAX_LIMIT = 10.0 FERROR = 0.050 MIN_FERROR = 0.005 #HOME = 0.000 #HOME_OFFSET = 0.10 #HOME_SEARCH_VEL = 0.10 #HOME_LATCH_VEL = -0.01 #HOME_USE_INDEX = YES #HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 1 # these are in nanoseconds DIRSETUP = 200 DIRHOLD = 200 STEPLEN = 40000 STEPSPACE = 40000 [JOINT_2] ## Y TYPE = LINEAR MAX_VELOCITY = 10 MAX_ACCELERATION = 20 # Set Stepgen max 20% higher than the axis STEPGEN_MAX_VEL = 12 STEPGEN_MAX_ACC = 24 BACKLASH = 0.000 SCALE = 1000 MIN_LIMIT = -10.0 MAX_LIMIT = 10.0 FERROR = 0.050 MIN_FERROR = 0.005 #HOME = 0.000 #HOME_OFFSET = 0.10 #HOME_SEARCH_VEL = 0.10 #HOME_LATCH_VEL = -0.01 #HOME_USE_INDEX = YES #HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 1 # these are in nanoseconds DIRSETUP = 200 DIRHOLD = 200 STEPLEN = 40000 STEPSPACE = 40000 [AXIS_Z] MIN_LIMIT = -10.0 MAX_LIMIT = 10.0 MAX_VELOCITY = 10 MAX_ACCELERATION = 20 [JOINT_3] ## Z TYPE = LINEAR MAX_VELOCITY = 10 MAX_ACCELERATION = 20 # Set Stepgen max 20% higher than the axis STEPGEN_MAX_VEL = 12 STEPGEN_MAX_ACC = 24 BACKLASH = 0.000 SCALE = 1000 MIN_LIMIT = -10.0 MAX_LIMIT = 10.0 FERROR = 0.050 MIN_FERROR = 0.005 #HOME = 0.000 #HOME_OFFSET = 0.10 #HOME_SEARCH_VEL = 0.10 #HOME_LATCH_VEL = -0.01 #HOME_USE_INDEX = YES #HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 0 # these are in nanoseconds DIRSETUP = 200 DIRHOLD = 200 STEPLEN = 40000 STEPSPACE = 40000 [HOSTMOT2] DRIVER=hm2_eth board_ip="10.10.10.10" debug=0 BOARD=7i96 CONFIG="num_encoders=1 num_stepgens=5"
7 years 6 months ago #130452 by PCW
Replied by PCW on topic Master branch gantry Mesa 7i96
I dont see anything obvious that would stop one of the Y axis from working but the velocities and limits are crazy for a mm machine. (10 mm/sec max velocity and +-10mm position limits)
These numbers might make sense for a small inch machine bit not for mm (scaling of 1000 =1u resolution seems high also)
I would set the step timings to something reasonable also
say
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
7 years 6 months ago #130465 by rodw
Replied by rodw on topic Master branch gantry Mesa 7i96
You need to manually add another joint to your INI file and configure it in Hal. This is generally just a cut and paste exercise but be careful the joint numbering agrees with your physical machine and the 7i96 inputs.
Then make sure the HOME_SEQUENCE = -1 for both sides of the gantry in the INI file
7 years 6 months ago #130508 by andypugh
rodw wrote: You need to manually add another joint to your INI file and configure it in Hal.
Are you sure? He seems to have 3 axes and 4 joints, as expected.
7 years 6 months ago #130509 by ikkuh
I was wondering too. Changed a lot an hour ago, but still not working. If I use Hallshow just three motion counter change, the fourth one stays at 0.
7 years 6 months ago #130513 by PCW
Are you saying that joint.2.motor-pos-cmd (y2 command) does not follow
joint.1.motor-pos-cmd (y1 command) _after_ homing?
Time to create page: 0.372 seconds
