Servo tuning issues (Velocity mode driven from 7i77)
7 years 5 months ago #132640 by adamj12b
A little late to the party but I may be able to shed some light on the Dyn4 Drives.
I retrofit my bed mill with them and 1kW servos and had a hell of a time getting them tuned to where I was happy. forum.linuxcnc.org/30-cnc-machines/33016...ofit?start=80#114020
First, The DMMDRV tunes the drive is position mode for auto-tuning, but according to DMM, its ok. Also, I was not getting full speed from the motor. Here is what tech support told me:
The auto tuning always puts the drive in position mode so it doesn't matter what the final control mode is. I t calculates the parameter depending on the load and not control mode. Don't worry about the inertia mismatch, the auto tuning usually does a very accurate job reading the load and setting the parameters.
In speed servo mode, the GEAR_NUM parameter is used to set the speed at 10V analog input. So I imagine your GEAR_NUM is currently set to the default 500 so it's only achieving ~430rpm.
Change GEAR_NUM to 3000 and put the drive into speed mode then test again. You should be close to 3000rpm at 10V input.
With that said, I was never able to get the drives and thus machine tuned, to my satisfaction using velocity mode. I ended up using torque mode and had way easier success. Originally, Feburary 2018, I tuned the drives by hand as the auto-tune we released a few weeks after I did this. I found out about the auto-tune a year later, Feb 2019 and decided to give it a shot. Even after understanding linuxcnc and servos a lot more, I was not able to get the velocity loop to work at the same results as previous torque mode. So I switched back to torque with re-tuned linuxcnc and the results were even better then before. In torque mode, It took a huge amount of P gain to get the system to be rigid.
Here is a picture of my Z axis tuning plot and pid settings. Andy told me on the IRC a few months back that this was tuned tighter then he could have bothered. :laugh:
Im curious to see your error plot.
As for hardware, I am running 1kW servos, with 2:1 belt reduction into 5TPI screws on all 3 axis. The line Num in the drive is set to 1000 to output the encoder signal as 1000 lines. Once quadrature decoded, thats 4000 CPR. * 2 for belt = 8000 and then *5 for the screw is the 40000 for the axis scale.
If you need a look at my working config, I can send some your way when I get to the machine. Just let me know.
Hope it helps
-Adam
7 years 5 months ago #132850 by fungus
Hey Adam!
Thanks for the tips. I'm a bit baffled why DMM buries the true gains from the end user. You can definitely still get it into non-working states, so they really should just open it up.
I am very confused about one thing: in the DYN4 manual , it specifically states that the GEAR_NUM parameter does not relate to anything but "Position Mode" and "RS-232" commands (seen on page 44 of above link).
Did you get a change from it? It shouldn't be valid for your torque loop either from what the manual indicates!
I was not able to use the auto-tuning, as every time it made the Integration Gain far too high (eventually faulting the drive due to over-temperature). I have belt drives (4:1), so it's not rigid enough to have much kI. I have about as much faith in auto-tuners as I do in auto-routers for PCBs ;)
I may not be able to get it to a satisfactory state, but I may get it good enough to cut some metal at low feed rates. Both my mill and lathe are down right now due to servo tuning issues. I need something that works!
I'll try to post a pic of my following error later this evening.
7 years 5 months ago #132886 by fungus
Here's the following error on the X axis. This is done by jogging with the "+/-" buttons in Axis.
Note the following error before and after the command... Before is above, after is below. Also, the overshoot at beginning and end are asymmetrical.
7 years 5 months ago #132889 by fungus
Hmm. I ran a modified version of the lathe_pawn example, and the following errors there are quite significant.
I'm at a bit of a loss as to what I should do here. Maybe scrapping this and going for the torque mode is the next step...
7 years 5 months ago #132891 by adamj12b
That is quite far off...
In usually don't have much faith in auto tuning but decided to note my config and give it a shot. It definitely helped big time in the ring on deceleration.
First, can you tell us more about your hardware. What is the machine? How much inertia? What motor model and voltage are for feeding the drive.
What I found surprising helpful, was don't pick the motor you have, but pick the next size up. This changes the the inertia mismatch calculation and thus gains. I picked the 1.3kw motor when I only have 1.0. also set all settings on the least rigid options. Then tweek them down. Temp issues are concerning. I have never had any issues with no active cooling.
-Adam
7 years 5 months ago #133568 by fungus
I asked DMM some questions regarding the issue. Followings is the reply:
Hello,
The tuning of the drive is all the same no matter the final operation mode.
I assume you already ran through the auto tuning from the program, correct?
If the motion is not ideal, you can let us know the problem and we can advise to adjust the Gain parameters manually.
You can also use the Test Movement in the parameters screen and set the movement to Step and increase the amplitude to maximum so the motor moves 45degrees at 1Hp. Then change the parameters while the motor is in motion so determine the best settings.
Normally for a lath the Integration Gain is set to 5 and does not need to be changed. Keep Speed Gain a bit lower than Main Gain and increase/decrease these two parameters until the motion is stable. For example, start with Main Gain at 10 and Speed Gain at 8 and increase until the movement is rigid.
I really don't dig the concept that the tuning is the same for separate modes. Really, the target market for these is probably those who will utilize the step/dir or serial command capabilities.
I'm going to attempt to tune up the "Torque" mode and see if I have better luck there.
Time to create page: 0.531 seconds
