Modbus (RS485) control for a Powtran PI9130 VFD
03 Jun 2019 16:12 - 03 Jun 2019 16:20 #135799 by sutter.michi
Hi everybody,
I am a little bit confused how to connect and set up my vfd with Linux CNC.
I have an USB <-> RS485 adaptor to do the connection between the vfd and the pc.
But now I am confused what I have to do, to setup the software correctly.
I tried this buildyourcnc.com/FAQ/13272https://buildyourcnc.com/FAQ/13272 but I doesn`t work with my vfd...
I read some information about mb2hal but don`t know exactly what to do now.
Can I use this with my actual version uf LinuxCNC or do I have to reinstall a newer version?
Which of these files exactly do I need?
Hope so much anyone can help me :)
Thanks a lot and best regards!!
Michi
Attatched the modbus parameter of the vfd:
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Last edit: 03 Jun 2019 16:20 by sutter.michi.
04 Jun 2019 16:09 #135861 by andypugh
How far have you got? Have you got as far as adding mb2hal to your HAL file and experimenting with it?
04 Jun 2019 17:23 #135869 by sutter.michi
Replied by sutter.michi on topic Modbus (RS485) control for a Powtran PI9130 VFD
No I haven`t tried it, because I am no really shure what`s to do...
Do I have to do a new compilation for LinuxCNC with these mb2hal files (Somwhere I have read about )?
Or is the only thing I have to do copy and paste these in my project folder?
04 Jun 2019 17:32 #135870 by Todd Zuercher
Replied by Todd Zuercher on topic Modbus (RS485) control for a Powtran PI9130 VFD
It might be a little simpler to use the modbus capability of Classicladder. But regardless configuring a modus control is rather complex.
05 Jun 2019 01:25 #135909 by andypugh
Neither. You simply have to add an entry to one of your HAL files and create an INI file to configure the Modbus transactions.
linuxcnc.org/docs/2.7/html/drivers/mb2hal.html
This isn't quite as clear as one might hope, but you need a file rather like that example file, and also need to add a line in one of the HAL files
loadusr -W mb2hal config=config_file.ini
where config_file.ini is set up to suit the register maps of your VFD.
05 Jun 2019 02:43 #135917 by sutter.michi
Okay, I try this! And experimenting with the hal files.
08 Jul 2019 16:33 - 08 Jul 2019 16:34 #138896 by sutter.michi
Hi!
I found help in a other forum.
It is in german, but if anybody has the same problems look there:
www.cnc-aus-holz.at/index.php?thread/124...62e8836da8a33fb2e0b9
This way is working!
Best regards
Michi :)
Last edit: 08 Jul 2019 16:34 by sutter.michi.
Time to create page: 1.455 seconds
