7i84 inverting output Pins
- 3D-Master
- Thank you received: 5
29 Jun 2019 08:30 #138175
by 3D-Master
7i84 inverting output Pins was created by 3D-Master
Hello,
is it normal that "watch" in halshow doesnt show you an inverted pin? (normally low but inverted so it should be high, but it shows the pin as low).
i have Linuxcnc 2.7.14
thanks
thanks
- Thank you received: 5337
29 Jun 2019 13:17 #138187
Replied by PCW on topic 7i84 inverting output Pins
The 7I84 (and all sserial devices) have inverted input pins available
but no inverted output pins. Output pins are usually active high ( high=1=true=ON )
- 3D-Master
30 Jun 2019 14:49 #138248
by 3D-Master
Replied by 3D-Master on topic 7i84 inverting output Pins
im sorry, i ment when you set the invert-parameter for an output pin to "true" then the output will be inverted (i measured it with a multimeter) but Halshow will still show the output pin as "low".
- Thank you received: 4155
30 Jun 2019 14:57 #138250
Replied by rodw on topic 7i84 inverting output Pins
There is always the invert component which will do what you want.
linuxcnc.org/docs/devel/html/man/man9/invert.9.html
30 Jun 2019 15:08 - 30 Jun 2019 15:10 #138252
That's correct, invert_output=true means:
hardware_output_pin <= not (hal_pin)
The hal_pin is not changed
Last edit: 30 Jun 2019 15:10 by PCW. Reason: clarify
The following user(s) said Thank You: 3D-Master
Time to create page: 1.753 seconds
