Twin Spindle / Twin Turret turning center
30 Sep 2020 15:03 #184386 by andypugh
Replied by andypugh on topic Twin Spindle / Twin Turret turning center
Two linuxcnc is probably the way but i can't find solution how to interconnect it and sending data from one to second. The only one function i found is linuxcncrsh for commanding linuxcnc over network.
I think that this would be best done with a custom setup where the controllers toggle dedicated GPIO pins that are read/written by G-code.
So, start with a list of what each controller needs to know about the other.
For example I would dedicate a digital pin that would tell the secondary spindle to sync speed exactly with the primary one, and then make the primary spindle angle available to the secondary one to use as a target for a position PID.
But, first of all, I would suggest making it work as a single-controller XZUW machine and use it for a while. That will help to realise what you need the machine to do, and give you a grounding in how to do it.
30 Sep 2020 20:22 #184411 by Todd Zuercher
Replied by Todd Zuercher on topic Twin Spindle / Twin Turret turning center
I can also imagine a set up that combines both, with a master control and daughter, where the master could control both sides as XZUW, or enable the daughter to execute synchronized code independently.
I think the hardest and most important part would be building the nessisary custom user interface capable of interacting with the daughter control. Hasn't there been some work on remote interfaces? This would seem to be the perfect use for such development.
04 Jan 2021 18:51 #194062 by rexo
Now i have working config, i am using 2 axis (X, Z) and 4 joints, for correction i use U and W column
basic tool correction is only in X,Z axis, in the U,W is only difference from X,Z
value is read from motion.tooloffset.u (w) and transferred to custom kinematics.
This solution is working, i have one program for 2 spindles and two tool turrets.
But i have one problem.
When tool and correction is loaded, then 3 and 4 axis is move to corrected position, but very slow.
This is due to pid, i don't known why. Axis is moving correctly, only correction moves is slow.
File Name: etkins.c
File Size:4 KB
04 Jan 2021 19:58 #194067 by cmorley
Replied by cmorley on topic Twin Spindle / Twin Turret turning center
Could you post your config files?
04 Jan 2021 20:16 #194070 by rexo
here is config files
File Name: et425.hal
File Size:20 KB
File Name: et425-axis.ini
File Size:5 KB
05 Jan 2021 11:40 #194136 by rexo
I try modify stepgen to position mode without pid and now it's working fine, offset moves is fast.
05 Jan 2021 18:57 #194162 by cmorley
Well thats odd. PID is preferred
I see P for joint 2 was 100 should be 1000
05 Jan 2021 18:59 #194163 by cmorley
Can you make a video of the lathe in action - very curious to see!
07 Jan 2021 00:25 #194312 by andypugh
I don't think that a change in the tool offset should _ever_ cause an axis movement until the next programmed move.
What you describe could happen if the pid pins were connected to the wrong inputs and outputs, but the HAL looks conventional enough.
But, anyway: If an axis moves with just a change in tool offset (rather than just the displayed position changing) then something is wrong somewhere.
Time to create page: 0.683 seconds
