Twin Spindle / Twin Turret turning center
5 years 9 months ago #194070 by rexo
here is config files
File Name: et425.hal
File Size:20.45 KB
File Name: et425-axis.ini
File Size:4.85 KB
5 years 9 months ago #194136 by rexo
I try modify stepgen to position mode without pid and now it's working fine, offset moves is fast.
5 years 9 months ago #194162 by cmorley
Well thats odd. PID is preferred
I see P for joint 2 was 100 should be 1000
5 years 9 months ago #194163 by cmorley
Can you make a video of the lathe in action - very curious to see!
5 years 9 months ago #194312 by andypugh
I don't think that a change in the tool offset should _ever_ cause an axis movement until the next programmed move.
What you describe could happen if the pid pins were connected to the wrong inputs and outputs, but the HAL looks conventional enough.
But, anyway: If an axis moves with just a change in tool offset (rather than just the displayed position changing) then something is wrong somewhere.
Time to create page: 0.054 seconds
