- Configuring LinuxCNC
- Advanced Configuration
- Dual PID loops and appropriate pins for feedback to the Trajectory Planner et al
- Thank you received: 1480
18 Sep 2019 21:26 #145538
Replied by Todd Zuercher on topic Dual PID loops and appropriate pins for feedback to the Trajectory Planner et al
I don't have any real experience with a dual feedback set up. I have only played with dual PIDs cascaded for controling a torque mode servo (pos-PID -> vel-PID -> servo torque command). Some other possible ideas to try might be using a single PID using the scale position feedback and the rotary encoder's velocity feedback, or calculating the following error from the linear encoder and plugging that into the bias input.
- HalaszAttila
- Thank you received: 5
19 Nov 2019 09:14 #150621
by HalaszAttila
Replied by HalaszAttila on topic Dual PID loops and appropriate pins for feedback to the Trajectory Planner et al
Hello,
in interesting in controlling axis with full closed loop too (Rotary encoder + Linear scale).
Have you got any results on this topic yet?
Best regards,
Attila.
Best regards,
Attila.
- akb1212
- Thank you received: 12
12 Dec 2019 14:39 #152534
by akb1212
Replied by akb1212 on topic Dual PID loops and appropriate pins for feedback to the Trajectory Planner et al
Hello,
As most of you already know, tuning a "normal" PID-loop is something like an art (even a black art...). So nesting loops isn't exactly simplifying things. Not as far as making things easier to understand and wrap your head around anyway!
But....
There are some clear advantages to be had by doing it! Which is also why most high end CNC-machines always have it.
So.....
I have already installed a second set of encoders on my mill (a 1990 MahoMH600E), a full WMC that came with original linear scales with high resolution (0,2 um with the present interpolators).
So I have installed quadrature encoders on the motors.
As far as I understand this there should be "clean" signal paths, and no mixing or sharing of feedback between the different PID's.
At least in my head it will be a problem when a PID is calculating its output based on a mix of feedback, which have a different time-domain. After all there is a delay between the mechanical arrival of the movements between the two encoders. In my case the inner loop is directly connected to the motor on its shaft. This is to have a fast response which enables high stiffness of the loop.
The outer loop on the other hand is connected to linear scales. And they have a much longer mechanical train before the movement arrives at them (in my case a safety clutch, a timing-belt, a ball-screw + nut, stick-slip from the ways and finally mechanical connection to the encoder)! As a result the loop is a lot slower, and as such one will have to back off on the control signals as the phase delay will become a problem. Oscillations will start at much lower gain levels (reducing speed and stiffness).
So..... since the main feature of the inner loop is it's high speed, and as a result high stiffness..... you wouldn't want to mix inn signals from the outer (slow!) feedback loop!
You would pollute your fast inner feedback loop with slow feedback signals from the outer loop, and as a result mess up the whole advantage.
When I read the wiki I don't interpret it as they mix the encoder signals.
BTW, one thing this implementation is capable of is to remove minor backlash and mechanical wear (an important thing for me). And it's doing it by taking feedback from before it's introduced. But to then use the (polluted with backlash) signal from the outer loop and introducing that in to the clean and fast inner loop will cause big problems.
Also take a look at my post discussing this with DaBit here:
PID tuning: one vs multiple loops, gain scheduling
I think he made his mill work with dual loop (plus an inner torque loop inside of that, but that is normaly done in the drive). But his newest links to the configs are dead..... his webpage where he had them are long dead. But there are early configs in the above mentioned thread.
I have taken up my work with my mill again now, after several years of no time to spend on it. And I hope to have this working soon. And will share my configs along the way. I'm soon ready to start testing out the new configs I'm working on now, and will most likely need some assistance to finish them.
Anders
But....
So.....
Anders
The following user(s) said Thank You: HalaszAttila
- Nitram
- Thank you received: 15
13 Dec 2019 14:44 - 13 Dec 2019 14:46 #152604
by Nitram
Replied by Nitram on topic Dual PID loops and appropriate pins for feedback to the Trajectory Planner et al
Hi Anders.
Whilst the 1um magnetic scales have now arrived I have not had time to mount them into my mill which has 10mm pitch and 4096 ppr encoders on the ballscrew of each axis already.
As a starting point for you, and after much trialing on a different machine, I found the best way of zeroing both measuring devices together (rotary and linear) at the instant of homing on a given axis, was a physical wire joining both Z pulses when homing to index.
It worked consistently and well.
I am interested in your progress with this project.
Kind regards
Marty.
Kind regards
Marty.
Last edit: 13 Dec 2019 14:46 by Nitram.
- Doug Crews
- Thank you received: 9
16 Feb 2021 18:51 - 16 Feb 2021 18:52 #199096
by Doug Crews
Replied by Doug Crews on topic Dual PID loops and appropriate pins for feedback to the Trajectory Planner et al
Hello Marty,
I know this is an old post but I’ve learned that time flies when working inside of this opensource machinery bubble!
It looks like you were planning to implement a dual loop. I’m wondering if you had shelved that project since you had such success with mapping your ball screws using the method you posted last year. By the way, Thanks for doing that. Its great example of sharing.
I’ve just finished up installing ball screws on my knee mill and am now faced with the decision of mapping or dual loop. I still have a small amount of backlash and also some lead error. My existing scales are 10 micron resolution, really coarse. I’m convincing myself that I should go ahead and get 1 micron scales even if I don’t go dual loop because it will help with the mapping process. I would value your opinion in this area and welcome any of your adventures you can share in the dual loop effort.
Doug
Doug
Last edit: 16 Feb 2021 18:52 by Doug Crews.
- Nitram
20 Feb 2021 22:17 #199566
by Nitram
Hi Doug.
Been quite busy lately, sorry i haven't replied sooner.
Just wondering where you are located on the chance you're also in Australia?
Cheers Marty.
Cheers Marty.
- Doug Crews
22 Feb 2021 04:49 #199675
by Doug Crews
Hi Marty, No worries glad to hear you are busy. Hopefully it’s all good stuff. I’m unfortunately not in Australia can’t wait to visit one day. I have neighbors who moved back there and would like to pay them a visit. I’m located in Seattle Washington USA. I’ve been working toward running a comp program following your post using my existing scales just to get the setup working. I should be able to get it going later this week. I keep telling myself to just go-ahead on the 1 micron scales, but maybe I can get better performance even with the 10 micron scales.
Cheers
Doug
Cheers
Doug
- Nitram
22 Feb 2021 09:06 - 23 Feb 2021 20:23 #199688
by Nitram
Last edit: 23 Feb 2021 20:23 by Nitram.
- Becksvill
- Thank you received: 115
04 Jan 2026 05:34 #340947
by Becksvill
Replied by Becksvill on topic Dual PID loops and appropriate pins for feedback to the Trajectory Planner et al
hey guys i am also about to try scales plus ballscrews and encoders on a larger machine
just posting here to see if Nitram is still online at all?
hoping to make this work and then document it a bit for people and maybe post a config that is working etc
cheers
Andrew
cheers
Andrew
- Doug Crews
06 Jan 2026 00:17 #341030
by Doug Crews
Hi Andrew,
I don’t have anything specifically for hal configs yet, but it is high on my to do list. Your inquiry has helped me to get off my butt and write up what I’ve been doing and experiencing. I have a knee mill with one micron scales, servo motors & drives configured in velocity mode and ball screws.
The ball screws are from Rockford ballscrew they have an adjustable design that is supposed to be able to adjust the backlash out. It kind of works. The problem is instead of backlash they have “wind-up” I guess technically its not backlash like “open space” but the wind-up causes problems very similar. Because adjusting the ball nuts takes a lot of time I put it off and that’s when things got really interesting. The wind-up became more and more, up to nearly +/- ten thousandths. I could measure it because I integrated the original hand wheel dials in my retro fit. The dials are an excellent reference for tuning, you can literally see the oscillations and overshoot. As you probably know because of the windup all of the direction changes in circular interpolations had oscillations which could be seen the halscope but also in the surface finishes but not really measurable. Going point to point was and still is spot on within a tenth. With so much easy windup in the ball nut the cutter would occasionally grab and take a really heavy bite (climb cutting) and pull the wok piece/table into the cutter. It was easy to hear and almost visually perceivable when it happened. When it happens it is so very fast, so fast that I believe it’s beyond the linear scale encoders ability to read and it misses counts and results in a position losses.
I’m pretty sure this is happening because when cutting a pocket that steps down in increments the pocket migrates. Since the grab usually happens in the same place on each level it migrates the same direction, it’s very repeatable. After a few pocket increments I would command the tool to go to program Zero and it go to where the control displays zero but it is NOT at work piece zero. When I back-off the cut parameters so there is no tool grabbing (really light cuts)there is no loss of position. My gut has been telling me this is most likely NOT a problem for large machines with very heavy tables and very little backlash and I’m not sure how much a dual loop feed back will help with the grab and missing counts situation with my machine. If the ballscrews were truly zero backlash there would be no problem, potentially no need for dual loop feedback. I’m going to try some things, hopefully I’ll get some time to do it this winter.
-Doug
-Doug
Time to create page: 0.155 seconds
