Dual PID loops and appropriate pins for feedback to the Trajectory Planner et al
2 months 4 weeks ago #348400 by cmorley
I wanted to add this to our docs some where for a guide to others.
When I looked at this and it seems you have both encoders connected to index-enable.
This seems wrong in my head, as it would depend on which encoder index fired first.
Any opinion or insight?
The following user(s) said Thank You: akb1212, NWE
2 months 4 weeks ago #348402 by NWE
I agree this sounds off. I suspect it will very likely always find the one index first, and I expect that to be the servo index, unless home switch is quite near to scale index. I think ideally you'd want to use only the scale index.
2 months 3 weeks ago #348455 by cmorley
I think this shows the basics of the summed PIDs.
The following user(s) said Thank You: tommylight, NWE
2 months 3 weeks ago #348506 by NWE
Perfect. I always thought I had to cascade them, which seems to multiply the tuning time and effort.
@cmorley I printed that and am hanging it on my wall for future reference
2 months 3 weeks ago #348518 by cmorley
Excellent. I will add it and a little writeup in the official docs.
2 months 3 weeks ago #348553 by Becksvill
Chris there is a bug with the index enable stuff i think when summing the PID loops like this. I forget exactly why i connected both encoder index pulses to index enable
i read i think earlier in this thread that you can connect both encoders to index enable and also connect them with a physical wire so the first index to fire triggers the homing. but i couldn't get it to work. rereading my post it sounds like i just messed this up but i really do think there is a bug. I could test if you want to go through with me and prove the issue. we have messaged off forum on messenger before..
so i tried just one PID loop with the velocity input coming from the encoder and the position input coming from the scale. and that homed to index enable fine but the tuning was really rough. i couldn't believe how bad it was. it was like there was a stuffed bearing on the ballscrew. and the axis kept bounching back and forth around the 0.1mm backlash which was unusable. and after i had just tested the other way with a smooth as silk axis that always stopped perfectly within 0.002mm I wasn't going back I talked about the mesa index enable issue with PCW a bit but i ran out of time to fully prove it was a bug. But i definitely think that having the 2 separate PID loops breaks the index enable logic.
anyway after all that i read somewhere on the forum that someone else had the same issue for some reason and the really inelegant solution is to run the home switch through classic ladder and have it trigger on the home switch first and then look for the change in homing state and on the next state when the encoder is searching for index pulse use classic ladder to feed it the encoder physical index pulse from rotary motor encoder on end of ballscrew. this means that you have to home that last little bit extra slow as it can miss the pulse. and it is not that best. But in saying that i haven't had it miss the pulse yet and it's not that much slower to home.
But i would like to fix this as this is the last annoyance that if it was fixed i would probably go crazy and put scales all over my machines lol
So Chris your classic ladder is still getting used all the time by people keep up the good work.
cheers andrew
Time to create page: 4.426 seconds
