5 axis kinematics modules
- Profed81
- Visitor
05 Oct 2020 01:50 #184935
by Profed81
Replied by Profed81 on topic 5 axis kinematics modules
Can you send me your configuration file?
- Profed81
- Visitor
05 Oct 2020 01:52 #184936
by Profed81
Can you share you configuration file?
- Profed81
- Visitor
08 Oct 2020 13:31 #185379
by Profed81
How do you change the world and joint mode?Hi Andy
Looks like a rookie error, I had it in joint mode! It works fine once in world mode. Cheers!
- Thank you received: 7505
08 Oct 2020 17:08 #185405
IIRC
Replied by tommylight on topic 5 axis kinematics modules
Shift + $How do you change the world and joint mode?
IIRC
The following user(s) said Thank You: Profed81
- Profed81
- Visitor
13 Oct 2020 23:03 #186059
by Profed81
Que necesito para que esa simulación mueva una máquina de verdad? Creo que debo agregar pins de paso y dirección, verdad?
- Profed81
- Visitor
13 Oct 2020 23:06 #186060
by Profed81
Esta simulación no trae cargado los módulos de kinematics?Que necesito para que esa simulación mueva una máquina de verdad? Creo que debo agregar pins de paso y dirección, verdad?
- Thank you received: 2177
14 Oct 2020 02:13 #186076
Replied by Aciera on topic 5 axis kinematics modules
I don't have my spanish hat on but I think you are trying to use a simulation config for a real machine.
Simulation configurations will not run a real machine because the inputs and outputs are simulated in the computer. The kinematics modules are loaded but all the signals stay inside of linuxcnc.
To run a real machine you need to create your own config that fits your attached hardware. So use "pncconfig" to create a basic configuration and then edit the created INI and HAL file in the directory that was created by pncconfig.
Time to create page: 0.520 seconds
