Adding Slicing to LCNC for DLP and LCD Printers
  • Bari
  • Bari's Avatar Topic Author
  • Platinum Member
  • Platinum Member
16 Oct 2019 06:41 #147970 by Bari
I'm working on support for slicing 3D models into layers for DLP and LCD type printers controlled by LCNC.
The GUI will use QtPyVCP github.com/kcjengr/qtpyvcp/
I have been looking a few different ways to synchronize image layers in a SVG that are displayed in sync with Z-axis movement with a projector or LCD onto the photopolymers.
One way is to build on what Andy had proven a few years ago using Python and Cairo.
Python code that shows layers using Cairo, but it gets the Z-coordinate from LinuxCNC HAL, so is a bit specific to the application. The operative code is
def expose_cairo(win, event, data):
cr = win.window.cairo_create()
x, y, w, h = win.allocation
cr.rectangle(x, y, w, h)
cr.set_source_rgb(0,0,0)
cr.fill()
cr.scale(data, data)
print "Rendering %s" % data
data.render_cairo(cr=cr, id=data)
return True
Python Code to display a single slice of SVG file as a LinuxCNC HAL component
github.com/andypugh/SVG_Slicer
I was also considering using custom M-codes to get the SVG layers.
Wonder what ideas people have for this? Other approaches might be using ImageMagick or GraphicsMagick for slicing and display.
16 Oct 2019 06:46 #147974 by pl7i92
nice projekt but does a CNC control realy need to be displaying all layers
the most comen Printer do not display any line of code at all
it is more a need of temps and speed
BUT i welcome this to be a improvement of the system to a full Mashine control
  • Bari
  • Platinum Member
  • Platinum Member
16 Oct 2019 06:56 #147978 by Bari
Code is not displayed. The first video shows the image layers (slices) being displayed by the projector that cure the photopolymer for each physical layer printed.
  • Bari
  • Platinum Member
  • Platinum Member
31 May 2020 05:27 #169477 by Bari
Decided to use Slic3r for slicing and a SVG widget for QTPYVCP.
forum.linuxcnc.org/show-your-stuff/39213...d-msla-mlcd-printers
Time to create page: 0.567 seconds
