Vismach - Add toolchange simulation
- ross_dev
22 Oct 2019 07:35 #148539
by ross_dev
Vismach - Add toolchange simulation was created by ross_dev
Hi
Reading through the docs for vismach, there's a section at the bottom that says
Did anyone manage to implement these? I Am particularly interested in the tool change visualisation but material removal would also be extremely useful.
Cheers
RD
Ideas
a gui function to import further .stl or .obj files while running the script => change tool, vise or working piece when running the software
machine simualtion of cutting: function to remove material from defined geometry
Cheers
RD
- Thank you received: 7505
22 Oct 2019 12:43 #148548
Replied by tommylight on topic Vismach - Add toolchange simulation
Removed spam message, thank you.
The following user(s) said Thank You: ross_dev
- Thank you received: 4658
23 Oct 2019 18:35 #148658
Did anyone manage to implement these? I Am particularly interested in the tool change visualisation but material removal would also be extremely useful.[/quote]
That would be cool. As far as I know nobody has tried it, or if they have they didn't report it here.
If you can figure out the Vismach source code, then feel free to have a go
Replied by andypugh on topic Vismach - Add toolchange simulation
The following user(s) said Thank You: tommylight, ross_dev
Time to create page: 0.483 seconds
