linuxcncrsh: Does not open files
- ummerland
02 Nov 2019 20:40 #149441
by ummerland
linuxcncrsh: Does not open files was created by ummerland
Hi community
I am developing a control software in .net that is using linuxcncrsh (emcrsh) to open some programs in order.
The commands i am calling are:
hello EMC RSHUSER 1.0
set enable EMCTOO
set open file.ngc
Sometimes that works, but most of the times it spids out the following error message in the command line:
emc/task/emctask.cc 399: interp_error: A file is already open
can't open file.ngc
I found a Issue on GitHub that is describing an issue where it would call an error on two subsequent file loads. That issue seems solved.
Is there a way to call a specific function in between to work arround this issue?
Or is there a way to completely solve this?
Thanks in advice
ummerland
set enable EMCTOO
set open file.ngc
can't open file.ngc
Thanks in advice
ummerland
- Thank you received: 4648
04 Nov 2019 23:51 #149561
Replied by andypugh on topic linuxcncrsh: Does not open files
Can you raise an issue report on this? Just so it doesn't get lost.
github.com/LinuxCNC/linuxcnc/issues
- dgarrett
- Thank you received: 297
05 Nov 2019 01:48 #149565
by dgarrett
Replied by dgarrett on topic linuxcncrsh: Does not open files
Use the abort command.
The following session works for me
(tested on 2.8~pre):
$ telnet localhost 5007
Trying ::1...
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
hello EMC me 1.0
HELLO ACK EMCNETSVR 1.1
set enable EMCTOO
set enable EMCTOO
set echo off
set echo off
set verbose on
SET VERBOSE ACK
set estop off
SET ESTOP ACK
set machine on
SET MACHINE ACK
set home -1
SET HOME ACK
set open ../../nc_files/3D_Chips.ngc
SET OPEN ACK
-----> OK
set open ../../nc_files/spiral.ngc
SET OPEN ACK
----> emc/task/emctask.cc 405: interp_error: A file is already open
----> A file is already open
set abort
SET ABORT ACK
SET OPEN ACK
----> that worked
set mode auto
SET MODE ACK
set run
SET RUN ACK
The following user(s) said Thank You: tommylight, ummerland
- ummerland
09 Nov 2019 18:04 #149998
by ummerland
Replied by ummerland on topic linuxcncrsh: Does not open files
The abort command is working great!
Thanks dgarrett;)
Thanks dgarrett;)
Time to create page: 0.123 seconds
