How to practically use camera offset
- SvenH
29 Nov 2019 07:13 #151500
by SvenH
How to practically use camera offset was created by SvenH
Now that I have my camera setup working and more or less adjusted, it is time to use it.
I can find the offsets in x and y but I cannot think of a way to enter these in to my system or gcode.
I could make a new tool in the tool table and enter the offsets there but then the system would want to go and measure tool length, which is impossible because the camera is out off reach in all axis.
Is it possible to define a tool that does not want to go to the tool length sensor?
Or is there another way to make the system know how to deal with the camera offsets?
- Thank you received: 4155
29 Nov 2019 11:41 #151513
Replied by rodw on topic How to practically use camera offset
On my plasma table, I have a laser cross hair pointer which basically does the same thing. I touchedoff at X=0, Y=0 and made a single spot with the plasma cutter. Then I jogged the machine so the laser was over that spot and read the XY coordinates. .
Then I wrote a Gmocappy macro that moves the torch from it present position to the laser position and execute a XY touchoff.
- Thank you received: 4658
02 Dec 2019 17:50 #151787
I imagine that your auto tool length measurement is a G-code remap?
In that case just add some code to that which returns without a measurement of the tool number = 99 (or whatever).
Alternatively load the camera "tool" with the M61 command.
Replied by andypugh on topic How to practically use camera offset
Time to create page: 0.195 seconds
