2.8/2.9 PID seems broken?
14 Dec 2019 12:04 #152659 by 3D-Master
2.8/2.9 PID seems broken? was created by 3D-Master
Hello,
i have updated from 2.7.14 to 2.8/2.9 but then my servo generated a huge following error. I control it using PWM and DIR signals and have a encoder directly wired to my 7i52s.
these were my PID parameters in 2.7.14 which were not perfect but okay:
P = 7.5
I = 12.5
D = 0.2325
FF0 = 0
FF1 = 0.25
FF2 = 0
i had approx 0.01-0.02mm following error but when i updated to 2.8/2.9 the following error increased to at least a millimeter (maximum following error for feed moves, not rapid)
i can change ff1 to 1 as well as 1000 but nothing changes so i think there is something broken. The automatically changed ini and hal files dont seem to have a mistake.
Is this ini entry correct?
# Axis Z
[AXIS_Z]
MIN_LIMIT = -200.0
MAX_LIMIT = 200
MAX_VELOCITY = 166.666667
MAX_ACCELERATION = 1000.0
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 4.0
MIN_FERROR = 1
P = 15
I = 15
D = 0.02
FF0 = 0
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0.0025
MAX_OUTPUT = 0
ENCODER_SCALE = 512
OUTPUT_SCALE = 10
MIN_LIMIT = -200.0
MAX_LIMIT = 200
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 5
HOME_USE_INDEX = YES
HOME_SEQUENCE = 0
if i delete "MAX_VELOCITY = 166.666667" and "MAX_ACCELERATION = 1000.0" from joint then the homing is way slower and the axis can have a following error greater than MIN_FERROR but linuxcnc wont go into estop.
14 Dec 2019 14:16 #152660 by PCW
Replied by PCW on topic 2.8/2.9 PID seems broken?
2.8+ and 2.9 have a bug fix in the PID component.
Previous versions always calculated the FF1 term from
and internal derivative even if the command derivative pin
was connected. The version in 2.8+ and 2.9 does use the
externally supplied command derivative. For whatever
reason, the joint velocity does not match the old calculated
command derivative (I suspect 1 servo thread time difference)
If you want the old behaviour, disconnect the PIDs command derivative
pins and FF1 will be calculated the same way as 2.6..2.8+
The following user(s) said Thank You: andypugh
18 Jan 2020 10:49 #155103 by 3D-Master
Replied by 3D-Master on topic 2.8/2.9 PID seems broken?
But why is it, that when i change FF1 nothing happens?
18 Jan 2020 11:02 #155104 by PCW
Did you comment out any statement like:
net x-vel-cmd => pid.x.command-deriv
Notice if you just dont connect net x-vel-cmd to
encoder velocity but leave the pid.x.command-deriv
connected to a signal (as shown above)
you will have a fixed 0 FF1
19 Jan 2020 12:25 #155169 by papagno-source
Replied by papagno-source on topic 2.8/2.9 PID seems broken?
I use 2.9 and have this situation :
loadrt hostmot2
loadrt [HOSTMOT2](DRIVER) config=[HOSTMOT2](CONFIG)
setp hm2_5i20.0.pwmgen.pdm_frequency 6000000
setp hm2_5i20.0.encoder.04.counter-mode 0
setp hm2_5i20.0.encoder.04.filter 1
setp hm2_5i20.0.encoder.04.index-invert 0
setp hm2_5i20.0.encoder.04.index-mask 0
setp hm2_5i20.0.encoder.04.index-mask-invert 0
setp hm2_5i20.0.encoder.04.scale [JOINT_4]INPUT_SCALE
net motor.04.pos-fb hm2_5i20.0.encoder.04.position pid.4.feedback mux2.9.in0
net motor.04.pos-fbout mux2.9.out joint.4.motor-pos-fb
net Bindex-enable hm2_5i20.0.encoder.04.index-enable joint.4.index-enable pid.4.index-enable
net encodervelocityb pid.4.feedback-deriv hm2_5i20.0.encoder.04.velocity
setp hm2_5i20.0.pwmgen.04.output-type 3
setp hm2_5i20.0.pwmgen.04.scale [JOINT_4]OUTPUT_SCALE
net emcmot.04.pos-cmd joint.4.motor-pos-cmd pid.4.command
i add command derive for 2.9 ?
this is correct for 2.9 : net encodervelocityb pid.4.feedback-deriv hm2_5i20.0.encoder.04.velocity ?
19 Jan 2020 13:33 #155177 by PCW
Yes fb-deriv is OK
dont connect the pid command-deriv pin
19 Jan 2020 14:57 #155195 by papagno-source
Hi.
When use fb-deriv , not use command-deriv in 2.9 ?
Because ?
But in 2.9 i write : setp pid.x.error-previous-target true or not important ?
19 Jan 2020 16:21 - 19 Jan 2020 16:23 #155202 by PCW
Some background:
The PID component has a little magic it uses for both feedback and commanded
derivative terms (D*fb-deriv and FF1*cmd-deriv) If these PID component pins are not
connected (not linked to a signal) the PID component calculates these derivatives internally.
You should always use the PIDs fb-deriv pin if you need D term in your PID tuning.
The reason to use it is that the encoders velocity estimation is better than just dfb/dt
which is used by the PID component if the fb-deriv pin is not connected.
The PID component had a long standing bug where it ignored the command-deriv pin.
This was fixed sometime ago in the 2.8 branch, allowing the PIDs command-deriv
pin to be connected to the trajectory planners velocity pin but unfortunately the way
the PID calculates the derivative and the trajectory planners velocity pin are not the
same ( there's a 1 servo cycle delay between them ) Because of this, if you wish to
retain the previous behaviour and tuning, its best to leave the PIDs command-deriv
pin unconnected (not connect to any signal)
You should in general always setp pid.x.error-previous-target true
regardless of version
Last edit: 19 Jan 2020 16:23 by PCW.
The following user(s) said Thank You: Dbsharp
26 Jan 2020 06:13 - 26 Jan 2020 11:27 #155791 by papagno-source
Hi.
I don't use D part for PID, but only P and FF1 part .
I use servo motor in closed loop on encoder with analog +/- 10volt command on M5i20
In this case for actual 2.9 master i use only Fb-deriv(D part not used ) or only Commnad-deriv(FF1 part) or both.
Thanks for reply
Last edit: 26 Jan 2020 11:27 by papagno-source.
26 Jan 2020 07:05 #155804 by bbsr_5a
Replied by bbsr_5a on topic 2.8/2.9 PID seems broken?
is there a BASE Setup for a PID driving a Stepper to Comen Drivers M542/Tb6600 Famile Drivers Step DIR
im on the way to get rid of a ATCRACK using axis Comands transfering to PID Carousell at position Commandings
and lost in all this values
Time to create page: 0.951 seconds
