Orient component revised
6 years 9 months ago #156286 by nkp
Replied by nkp on topic Orient component
/* sudo halcompile --install shome.comp */ component shome "Provides a PID command input used for spindle homing"; pin out bit homing ; pin out bit homed ; pin in bit enable ; pin io bit index_enable ; pin out float command ; pin in float velocity = 100 ; variable int last_enable = 0; option fp yes; function _ "Spindle homing helper. Sets the encoder index-enable and waits for the falling of this signal."; author "Diego Weizel"; description ""; license "GPL"; ;; FUNCTION(_) { if (enable) { if (enable ^ last_enable) { // positive edge on enable homed = 0; homing = 1; index_enable=1; command=velocity; } if (homing && !index_enable) { // falling edge on enable homed = 1; homing = 0; command=0; } } else { homed = 0; homing = 0; command=0; } last_enable = enable; }
6 years 9 months ago - 6 years 9 months ago #156287 by nkp
loadrt orient addf orient.0 servo-thread loadrt mux2 count=2 addf mux2.0 servo-thread addf mux2.1 servo-thread loadrt shome addf shome.0 servo-thread loadrt near count=2 addf near.0 servo-thread addf near.1 servo-thread loadrt not count=1 addf not.0 servo-thread # reley 5 setp near.1.in1 0.0 net spindle-cmd near.1.in2 net reley-5 near.1.out not.0.in net reley not.0.out hm2_7i92.0.7i77.0.0.output-01 #-spindle-at-speed net spindle-vel-cmd => near.0.in1 net spindle-vel => near.0.in2 # 10% setp near.0.scale 1.1 loadrt or2 count=2 addf or2.0 servo-thread # addf or2.1 servo-thread net or2-0-in0 or2.0.in0 <= near.0.out net orient-mode or2.0.in1 #net spindle-at-speed motion.spindle-at-speed or2.0.out setp motion.spindle-at-speed 1 # encoder feedback setp hm2_7i92.0.encoder.05.counter-mode 0 setp hm2_7i92.0.encoder.05.filter 1 setp hm2_7i92.0.encoder.05.index-invert 0 setp hm2_7i92.0.encoder.05.index-mask 0 setp hm2_7i92.0.encoder.05.index-mask-invert 0 setp hm2_7i92.0.encoder.05.scale 4096 # spindle HOME net spindle-index shome.0.index-enable hm2_7i92.0.encoder.05.index-enable # PWM Generator signals/setup setp hm2_7i92.0.7i77.0.1.analogout5-scalemax 1500 setp hm2_7i92.0.7i77.0.1.analogout5-minlim -1500 setp hm2_7i92.0.7i77.0.1.analogout5-maxlim 1500 # spindle enable setp hm2_7i92.0.7i77.0.1.spinena 1 ################################################## #loadrt pid (main.hal) addf pid.vel.do-pid-calcs servo-thread # Velocity addf pid.pos.do-pid-calcs servo-thread # Position net spindle-pos pid.pos.feedback orient.0.position net shome-enable0 axis.2.homed classicladder.0.in-00 net shome-enable1 shome.0.enable classicladder.0.out-00 net mux1in0 mux2.1.in0 pid.vel.output net mux1in1 mux2.1.in1 shome.0.command net mux1sel mux2.1.sel shome.0.homing setp shome.0.velocity -3 net spindle-vel pid.vel.feedback hm2_7i92.0.encoder.05.velocity net spindle-vel-cmd motion.spindle-speed-out pid.vel.command net spindle-vel-pid mux2.1.out mux2.0.in0 net spindle-pos pid.pos.feedback orient.0.position hm2_7i92.0.encoder.05.position net spindle-pos-cmd orient.0.command pid.pos.command net spindle-angle motion.spindle-orient-angle orient.0.angle net spindle-pos-pid pid.pos.output mux2.0.in1 # this switches modes net orient-mode motion.spindle-orient orient.0.enable pid.pos.enable mux2.0.sel net velocity-mode motion.spindle-on pid.vel.enable setp scale.0.gain -1 ##+++++++++++ loadrt limit2 addf limit2.0 servo-thread setp limit2.0.maxv 1000 net spindle-cmd mux2.0.out => scale.0.in net scaleout scale.0.out hm2_7i92.0.7i77.0.1.analogout5 #net spindle-ramped <= limit2.0.out => hm2_7i92.0.7i77.0.1.analogout5 # Tune the PID from the INI values setp pid.vel.Pgain [SPINDLE]PGAIN_V setp pid.vel.Igain [SPINDLE]IGAIN_V setp pid.vel.Dgain [SPINDLE]DGAIN_V setp pid.vel.FF0 [SPINDLE]FF0_V setp pid.vel.FF1 [SPINDLE]FF1_V setp pid.pos.Pgain [SPINDLE]PGAIN_P setp pid.pos.Igain [SPINDLE]IGAIN_P setp pid.pos.Dgain [SPINDLE]DGAIN_P setp pid.pos.FF0 [SPINDLE]FF0_P setp pid.pos.FF1 [SPINDLE]FF1_P
Last edit: 6 years 9 months ago by nkp.
6 years 9 months ago #156288 by nkp
this hal file is still being edited, inaccuracies may be present
6 years 9 months ago #156290 by nkp
INI:
[SPINDLE] PGAIN_V = 0 IGAIN_V = 0 DGAIN_V = 0 FF0_V = 1 FF1_V = 0 PGAIN_P = 150 IGAIN_P = 1 DGAIN_P = 0 FF0_P = 0 FF1_P = 1
6 years 8 months ago - 6 years 8 months ago #156412 by alkabal
Replied by alkabal on topic Orient component
Hi
Regarding to your component i have try to add something similar.
Attached is the revision with the spindle home after machine homing included.
HAL patrs need to add a or2 component for pid enable.
##################################################################### # Spindle orient mode ##################################################################### loadrt orientv4 names=orient.orient-spindle loadrt pid names=pid.orient-spindle loadrt or2 names=or2.orient-spindle-pid-ena addf orient.orient-spindle servo-thread addf pid.orient-spindle.do-pid-calcs servo-thread addf or2.orient-spindle-pid-ena servo-thread # setup Orient Spindle PID setp pid.orient-spindle.Pgain [ORIENT]P setp pid.orient-spindle.Igain [ORIENT]I setp pid.orient-spindle.Dgain [ORIENT]D setp pid.orient-spindle.FF0 [ORIENT]FF0 setp pid.orient-spindle.FF1 [ORIENT]FF1 setp pid.orient-spindle.FF2 [ORIENT]FF2 setp pid.orient-spindle.bias [ORIENT]BIAS setp pid.orient-spindle.deadband [ORIENT]DEADBAND setp pid.orient-spindle.maxerror [ORIENT]MAX_ERROR setp pid.orient-spindle.maxerrorI [ORIENT]MAX_ERROR_I setp pid.orient-spindle.maxoutput [ORIENT]MAX_OUTPUT setp orient.orient-spindle.vel-speed [ORIENT]VEL_SPEED setp orient.orient-spindle.tolerance [ORIENT]AT_ANGLE_TOL # Set asked mode from M19 P0/1/2 net spindle-orient-mode <= motion.spindle-orient-mode net spindle-orient-mode => orient.orient-spindle.mode # pid output mux with regular spindle modul net DAC-ctrl-out-orient <= pid.orient-spindle.output net DAC-ctrl-out-orient => orient.orient-spindle.cmd-orient net DAC-ctrl-out-velocity => orient.orient-spindle.cmd-velocity net DAC-computed-ctrl-out <= orient.orient-spindle.cmd-out net DAC-computed-ctrl-out => hpg.pwmgen.00.out.00.value # enable out for controler from regular spindle or orient mode net spindle-enable => orient.orient-spindle.ena-velocity net spindle-orient-enable-out <= orient.orient-spindle.ena-out net spindle-orient-enable-out => fur.do-6 # enable output for VFD muxed with regular spindle modul # encoder connections index + feedback net spindle-index-enable => pid.orient-spindle.index-enable # need investigation net spindle-pos => orient.orient-spindle.position net spindle-pos-deg <= orient.orient-spindle.scaled-angle-out # Spindle orient control signals net spindle-orient-enable <= motion.spindle-orient net spindle-orient-enable => orient.orient-spindle.enable net spindle-orient-enable => or2.orient-spindle-pid-ena.in0 net spindle-orient-home-enable <= orient.orient-spindle.homing net spindle-orient-home-enable => or2.orient-spindle-pid-ena.in1 net spindle-orient-or2home-ena <= or2.orient-spindle-pid-ena.out net spindle-orient-or2home-ena => pid.orient-spindle.enable net spindle-index-enable <=> orient.orient-spindle.index-enable net machinehomed <= axis.0.homed net machinehomed => orient.orient-spindle.machine-is-homed # Is oriented near signal + link position asked to component net spindle-orient-degree-cmd <= motion.spindle-orient-angle net spindle-orient-degree-cmd => orient.orient-spindle.angle net spindle-is-oriented <= orient.orient-spindle.is-oriented net spindle-is-oriented => motion.spindle-is-oriented ## Command to pid from component by velocity and velocity feedback net spindle-orient-vel <= orient.orient-spindle.command net spindle-orient-vel => pid.orient-spindle.command net spindle-vel-fb-rps => pid.orient-spindle.feedback
In my opinion this is not the cleanest way for homing the spindle because motion or halui do no know what append.
I think is better to think about adding this feature in motion and or halui.
Edit : homing does not work correctly
Last edit: 6 years 8 months ago by alkabal.
6 years 8 months ago #157063 by andypugh
Replied by andypugh on topic Orient component
tommylight wrote: You can speak here, that is OK, but you might have to wait till Andy gets to read this as he is the original programmer of the orient component.
Actually, it was Michael Haberler: linuxcnc.org/docs/2.7/html/man/man9/orient.9.html
Part of the reason for adding the multi-spindle changes (actually the main reason) is that I wanted to add spindles to the homing sequence.
But I simply have not done that yet.
If anyone fancies it, I imagine sections in the INI
[SPINDLE_0]
HOME_SEQUENCE 4
HOME_VELOCITY 10
And then the system sets spindle index-enable, rotates at the given speed, then stops the spindle when the index resets.
Time to create page: 0.345 seconds
