- Thank you received: 2181
Orient component revised
alkabal wrote: now i understand why you want spindle on with S0, but it is better to have your setup or use a orient component ?
can i ask more about what you have do in your config ?
So My indexer is not going to work with you rorient component because it's stepper based.
My main spindle is a servo motor, but currently can only run i one direction.
I haven't had a chance to set up rour orient on my main spindle yet.
I did find where linuxcnc sets M5 when S=0, so i want to test that change too.
Chris
Saad but this yes this component is do for regular motor.cmorley wrote: So My indexer is not going to work with you rorient component because it's stepper based.
Chris
giz wrote: I don't have anything to contribute, but I'm trying to follow this conversation. I've had a horrible time trying to program a working Orient on my machine.
Hi i have see your topic some time ago when i try to setup original orient.comp but imo this component is really hard to setup correctly .
I like if you can check about this work in progress new comp i have do the most possible for allow easy setup.
copy past hal exemple from comp
add pid settings
remove 2 hal link from spindle setup and past to orient hal maybee adapt net link name for match your spindle net link name for this 2 link
first change :
#net spindle-enable => [HMOT](CARD0).7i83.0.0.analogena0 # moved in the orient input output
net spindle-enable => orient.orient-spindle.ena-from-velocity
net spindle-orient-enable-out => [HMOT](CARD0).7i83.0.0.analogena0 # moved in the orient input/output but initially in spindle setup
second change :
#net spindle-vel-cmd-out => [HMOT](CARD0).7i83.0.0.analogout0 # moved in the orient input output
net spindle-vel-cmd-out => orient.orient-spindle.cmd-from-pid-velocity
net spindle-orient-ctrl-out => [HMOT](CARD0).7i83.0.0.analogout0 # moved in the orient input/output but initially in spindle setup
But unfortunately it will probably be some weeks out. Happy to help how I can though
Please give the working hal file and ini pid section ORIENT
I think all is already here but i have attached my ini hal comp and pyvcp for reference;
Some parts of the oreint process are not really finished and need review, any help are really welcome.
-Analog with +-10v for speed and direction management like kbmg-212D
-Analog with 0/10v for speed and relay for swapp motor wire
-Analog with 0/10v for speed and one or two input for direction selection like Omron MX2
I think this can work with PWM spindle control
Please help is needed for do something better :
-Some issue with jog mode need/can be enhanced
-I'm sure the whole positionnement method can be better with more knowledge
Imo my attempt is mostly interesting for the safe and easy integration in existing config. (positonement is accurate)
Edit : updated revision with two relay management like Serg452 setup with Omron MX2
