- Thank you received: 52
Orient component revised
5 years 11 months ago #190378
by alkabal
Replied by alkabal on topic Orient component revised
Please attach your config it's better for checking.
I thinks some link was possibly wrong
5 years 11 months ago #190382
by Serg452
Replied by Serg452 on topic Orient component revised
and message when searching (attachment)
5 years 11 months ago - 5 years 11 months ago #190387
by alkabal
Hi you can you try with this edited version ?
I does not really understand your spindle pid /scale but you need in the range value for orient pid (i suggest setup your spindle pwm/scale/pid with rpm value i think this is more easy to follow)
[ORIENT]
MAX_OUTPUT =
VEL_SPEED =
And for sure you need to tune orient pid ! (for start you need to found the minimum speed allowed by spindle drive with a pid with only FF0 to 1, all other to 0 )
good luck !
Ps : i'm unsure about this because you write cmd, the component need velocity feedback from encoder not velocity cmd from motion
IMO you need this "net spindle-velocity to_pci.1.feedback.enc_vel2 => spindle.0.speed-in" but i think this is RPS RELATIVE so you need to convert as RPM ABSOLUE
net spindle-vel-cmd-rpm-abs => pid.orient-spindle.feedback # ABSOLUE IF USE WITH RELAY FOR DIRECTION or if DRIVE NEED INPUT = PID always positive
net spindle-vel-cmd-rpm-abs => orient.orient-spindle.vel-feedback # ABSOLUE IF USE WITH RELAY FOR DIRECTION or if DRIVE NEED INPUT = PID always positive
[ORIENT]
MAX_OUTPUT =
VEL_SPEED =
good luck !
Last edit: 5 years 11 months ago by alkabal.
5 years 11 months ago #190388
by alkabal
about
forum.linuxcnc.org/media/kunena/attachme..._20201126_201742.jpg
I don't really know but the orient message use MDI so i suspect some of your button control change the program status and does not allow to use MDI command at this moment, i think nothing other from orient use MDI.
5 years 11 months ago #190407
by Serg452
with this, the hal spindle does not turn on at allalkabal wrote: Hi you can you try with this edited version ?
what is in this meaning? maximum spindle speed? or orientation speed?alkabal wrote: VEL_SPEED =
5 years 11 months ago #190408
by Serg452
What signal is the basis for activating the drive for index mark search? Homed?
Time to create page: 0.156 seconds
