Orient component revised
5 years 5 months ago - 5 years 5 months ago #209580 by alkabal
Replied by alkabal on topic Orient component revised
I think my setup is near that you try with this man.
Spindle component for ramp up and ramp down before stop and ramp down before changing direction
Orient with jog mode and homing facility
I do not need to reset index when i switch mode because i do first a homing spindle with always the same speed, so the index position stay allways the same.
Last edit: 5 years 5 months ago by alkabal.
5 years 5 months ago #209703 by andypugh
Replied by andypugh on topic Orient component revised
One problem with the existing component is that if the input angle changes after enable, then the output angle does not change. Which means that it works for a one-time orient, but not to turn a spindle into an axis.
5 years 5 months ago - 5 years 5 months ago #209705 by alkabal
with my revised one if you call other angle from M19 before position reached the new angle is immediately applied, same for jog.
we can't ask multiple angle excepted if you wait the first angle is reached before ask other one.
Using C axis each time i stop spindle or after other move : the spindle try to return to the last C angle (i like to found a way for prevent this)
I have not tested what append if i call multiple C angle but imo that need more work in the orientv2.comp
5 years 5 months ago - 5 years 5 months ago #209706 by alkabal
I like the idea to create a sim config but i'm unsure is sim_spindle.comp is enough, i have never use sim personal sim config
I think i need this as simulated :
net spindle-index-enable <=> [HMOT](CARD0).encoder.00.index-enable net spindle-pos <= [HMOT](CARD0).encoder.00.position net spindle-vel-rps-raw <= [HMOT](CARD0).encoder.00.velocity # speed as RPS net spindle-vel-rpm-raw <= [HMOT](CARD0).encoder.00.velocity-rpm
5 years 5 months ago - 5 years 5 months ago #209714 by alkabal
At the end config sim work without emulated velocity this is crazy !
Unfortunately not all the stuff can be tested without velocity and after a moment i get pid saturated error.
Edit found the sim_encoder that work very fine !!!!:)
5 years 5 months ago - 5 years 5 months ago #210829 by alkabal
Hi
Any help welcome for write logic for use spindle vfd as C axis, for now i'm unsure about the correct behavior.
(For the moment i can only use sim config and it's more hard to understand what append.)
Also i like to have more detail about how is managed :
The idea there was to index-reset when the mode switches, which feels like a good idea. Now it has become a C-axis rehome when the mode switches.
Time to create page: 0.164 seconds
