hal file edit help
- Dinuka_Shehan
- Thank you received: 26
08 Mar 2020 22:24 #159558
by Dinuka_Shehan
hal file edit help was created by Dinuka_Shehan
i have tried many ways in stepconfig and add codes to hal files and nothing bring me to success.
can you please edit those files to my system,
my encoder 100ppr quadrature encoder.
cnc breakout board using no mesa card,
- Thank you received: 7505
09 Mar 2020 06:33 #159573
Replied by tommylight on topic hal file edit help
This is the 4'th topic you are starting with the same issue/content.
Please stop doing that, it is very hard to help you chasing through several topics.
- Dinuka_Shehan
09 Mar 2020 07:09 #159574
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic hal file edit help
Ok
Delete them if not necessary.
Will i want to report them to delete?
Problem resolved.
Cheap breakout not get encoder readings.
Change the breakout board more versatile than that.
Get the spindle speed reading.
Problem resolved.
Time to create page: 0.159 seconds
