Non-circular boring. (Linuxcnc fun)
6 years 7 months ago #162049 by cmorley
It does an amazing jog in the corners.
Linuxcnc is pretty damn cool.
What the next challenge...
6 years 7 months ago #162052 by skunkworks
Isn't it? I would like to add a bit more functionality to the comp.. I would like to make it cut outside polygons. (not that you really need to on a mill - but on the lathe it would be cool.) I would also like to add a rotation per z movement. A coworker mentioned it - You should be able to create a twisted polygon. (I think it would be cool to make a 'nut and bolt' that was a twisted hex..)
Don't know why... Because?
cmorley wrote: It does an amazing jog in the corners.
6 years 7 months ago #162053 by cmorley
outside polys could be interesting for building a driving square inside a bore - rare but interesting.
So no gcode for this right?
If that is the case a M code to turn it on and off would be handy.
Chris
6 years 7 months ago #162054 by cmorley
oh outside poly for making molds too .. opens up possibilities
6 years 7 months ago #162055 by skunkworks
I think packaged up in a nice re-map would be good. But currently I am just setting hal pins from gcode (m64/65 and such for enabling/diabling and so on). if you are slaving the x axis to the radius of the polygon - then yes - gcode 'modifies' the motion.
cmorley wrote: oh outside poly for making molds too .. opens up possibilities
6 years 7 months ago - 6 years 7 months ago #162094 by alkabal
Hi
I see you speak about lathe, did you think your actual .comp can work with lathe ? Can you think about including oval/eccentric ?
I will like to do a gladevcp panel like Andy lathe-macro for polygon/oval/eccentric but for now this is less than a beta. (started without your comp)
EMBED_TAB_NAME = Polygon/Oval EMBED_TAB_LOCATION = ntb_preview EMBED_TAB_COMMAND = gladevcp -u ./python/lathpolygonhandler.py -x {XID} ./lathepolygonmacro-fr-numpad.ui
Br
Last edit: 6 years 7 months ago by alkabal.
Time to create page: 0.270 seconds
