Non-circular boring. (Linuxcnc fun)
6 years 7 months ago #160671 by Todd Zuercher
or should it be hexy.
6 years 7 months ago #160824 by alkabal
Really cool stuff, for now my mill is only 10% finished so i can't play with your component but i'm really impatient.
Actually i try to include (difficult to understand) to my lathe config something similar done by andypugh for excentric turning (oval + polygon).
I'm waiting for other reply lol
Br
6 years 7 months ago #161229 by Abros
Brilliant work
6 years 7 months ago #161259 by rodw
alkabal wrote: Really cool stuff, for now my mill is only 10% finished so i can't play with your component but i'm really impatient.
Br
On a version of Linuxcnc 2.8 and above, there will be a number of sims installed on your system you can play with using external offsets. Pretty sure that is what Andy used here to offset the axis based on the spindle position.
6 years 7 months ago #161274 by skunkworks
I also output actual position offsets for using the 'offset' component and limit3. I tested it and it seems to work very much the same.
Br
6 years 7 months ago #162048 by skunkworks
More fun.. Aluminum!
You can see the spindle encoder resolution.
The following user(s) said Thank You: phillc54, arvidb
Time to create page: 0.571 seconds
