Non-circular boring. (Linuxcnc fun)
5 years 11 months ago - 5 years 11 months ago #190799 by alkabal
Hi
I come back trying to add your component to my lathe config, studying a little your code vs eoffset_per_angle, [strike]i have one questionn for knowledge : is there any reason than you not use the new official eoffset_per_angle[/strike] ?
Edit at the end i see that you use the new feature (axis.x.eoffset-enable) but you load "that i think is old style loadrt offset" is there any reason than do not use "the new style loadrt eoffset_per_angle" ? i see you use offset for joint.0.motor-pos-cmd joint.0.motor-pos-fb that seem to be automatically managed with eoffset_per_angle.
Have you any new version ready to share ?
I have so much question and so much trouble for understand correctly, can you also share some Gcode exemple that you use for create bolt in one setup and for cam profile ?
For exemple i'm right thinking for lathe there is no need to use cutterdiam and toolang ?
Ps : i have try start to write a beta halfile more easy to read and include for newbee
Ps 2 : I now think loadrt offset is not used anymore but as you can see i'm a little lost :blush:
Last edit: 5 years 11 months ago by alkabal.
5 years 7 months ago - 5 years 7 months ago #200775 by jpg
hello to all, I would like to try the "HAL" of skunkworks, but as I am beginner with linuxcnc, is there a tuto to make tests, here is what I know how to make at the present time.
:cheer:
Last edit: 5 years 7 months ago by jpg.
5 years 7 months ago #200850 by andypugh
There are HAL tutorials and documents on the LinuxCNC web page.
That won't tell you all you need to know, but might help to frame specific questions.
See the "HAL" section here:
linuxcnc.org/docs/2.8/html/
5 years 7 months ago - 5 years 7 months ago #200893 by jpg
hello Andy and the whole "linux" community without you all, I couldn't have done it :-)
As far as we are concerned here, I would like to know if the easiest way is to put the whole thing (the ALKABAL compilation) in the directory and if the GCODE can be generated by an external fao, like masterscam or other.
thank you for your help:
a link here; in French:
www.usinages.com/threads/comment-program...-excentrique.133077/
5 years 7 months ago - 5 years 7 months ago #200925 by alkabal
I'm also french. ;)
If you ask me : imo using my hal exemple can be a good starting point.
But for your question about gcode, this is for now not possible, skunkworks use command line terminal for change some hal value on the fly thats all.
If you like to use Gcode Remap macro or custom gui all need to be coded !
Last edit: 5 years 7 months ago by alkabal.
3 years 7 months ago #266872 by skunkworks
an actual application ;)
Time to create page: 0.280 seconds
