How to access RS485 on Mesa 7i96?
  • MakingStuff
  • MakingStuff's Avatar Topic Author
  • Premium Member
  • Premium Member
24 Mar 2020 17:13 #161372 by MakingStuff
How to access RS485 on Mesa 7i96? was created by MakingStuff
I was watching a video on YouTube where a USB RS485 device was used to control a VFD spindle. I was wondering if it is possible to do this using the RS485 port on the Mesa 7i96 instead of having to use an extra USB device.
Here is the code that was used to access the USB device. Is it even possible to do this with the Mesa 7i96? If so what would I change?
loadusr -Wn vfd hy_vfd -n vfd -d /dev/ttyUSB0 -p none -r 9600
net spindle-cmd-rpm-abs => vfd.speed-command
net spindle-cw motion.spindle-forward =. vfd.spindle-forward
net spindle-ccw motion.spindle-reverse => vfd.spindle-reverse
net on motion.spindle-on => vfd.spindle-on
24 Mar 2020 18:19 #161378 by PCW
Replied by PCW on topic How to access RS485 on Mesa 7i96?
Unfortunately this is not doable yet
The following user(s) said Thank You: MakingStuff
26 Mar 2020 18:18 #161633 by andypugh
Replied by andypugh on topic How to access RS485 on Mesa 7i96?
That depends on how you define "doable".
I think all that is missing is a modbus driver for the Mesa UART?
26 Mar 2020 19:04 #161639 by PCW
Yes, hoping at some point that a string hal type would allow decoupling
the low level driver from the formatter component (modbus etc)
27 Mar 2020 03:17 #161689 by strahlensauger
Replied by strahlensauger on topic How to access RS485 on Mesa 7i96?
In several FAQ plenty oft people asking to connect
Mesa cards via the rs422 to a vfd. Wouldn't it be possible to add a second rs 485 in future releases oft the cards?
28 Mar 2020 16:29 #161842 by andypugh
The physical connection is not really the problem, it is getting the right data to the the FPGA.
I wonder if there is a way to make the Mesa UART appear in /dev as a serial port?
28 Mar 2020 16:53 #161845 by PCW
Its probably possible but I think a cleaner way would be to support a hal string type
so this can all be done by a generic hal protocol component connected to the hal pins
exported by the UART TX and RX modules. This avoids losing real time if its desired
(and even if modbus for example is not real time, there's no reason to add userland
uncertainly to transactions)
28 Mar 2020 19:40 #161892 by andypugh
Indeed. But that would require re-writing of all the existing VFD drivers, which currently hook in to /dev/ttyUSB0
Time to create page: 0.119 seconds
