[solved] change axis-limits through hal-pins
  • Aciera
  • Aciera's Avatar Topic Author
  • Administrator
  • Administrator
01 Apr 2020 18:20 - 01 Apr 2020 18:27 #162404 by Aciera
The creation of kinematics switching has opened a number of new possibilities. One problem I have been struggling with is the fact that with switching kinematics the axis-limits set in the INI also need to be adjusted.
So I recently started a topic that I deleted before anybody could answer because I thought I had found the solution when I found the ini.N.min_limit and ini.N.max_limit HAL-pins.
I thought it was worth reposting this question as solved since dgarrett has kindly provided detailed information regarding this in another thread:
@Aciera re: ini hal pins
Is there a way to alter the min- and max-axis limits
ini hal pins are available for both JOINT_N and AXIS_L
MIN_LIMIT,MAX_LIMIT,MAX_ACCELERATION, MAX_VELOCITY
See the milltask man page (especially notes at bottom):
linuxcnc.org/docs/master/html/man/man1/milltask.1.html
In general, an interp-motion sync is needed for ini hal pins
to be recognized for subsequent motion but the sync is
needed to switch kins types anyway.
Recent dgarr/s_kins docs (not commited yet):
www.panix.com/~dgarrett/stuff/switchkins.html
See 3.3 Inifile Limit settings
And intree examples for M128,...:
github.com/LinuxCNC/linuxcnc/blob/dgarr/...ach/puma/mcodes/M128
Last edit: 01 Apr 2020 18:27 by Aciera.
The following user(s) said Thank You: tommylight, bbsr_5a
02 Apr 2020 01:50 - 02 Apr 2020 01:55 #162426 by bbsr_5a
Replied by bbsr_5a on topic [solved] change axis-limits through hal-pins
solved with no relpay is cool Than you
Question doent the Interpreter make a error if thel imits on the Axis side differ to the joint side
Last edit: 02 Apr 2020 01:55 by bbsr_5a.
  • Aciera
  • Administrator
  • Administrator
02 Apr 2020 10:23 #162452 by Aciera
No, having different limit values for axis and joints is no problem.
23 Dec 2021 14:17 #229829 by szary11
Replied by szary11 on topic [solved] change axis-limits through hal-pins
Gents,
I need some help. For tool change I have to change max limit of Z axis from 0 to 140, perform the toolchange and then switch it back to original one.
I have used ini.z.max_limit and that seems to be set ok, I see the borders of working space reflected on axis visual window and the pin value change on Show HAL Configuration menu.
But still, motion seems to be unaware of limits change, whenever I try to move Z into positive values, it throws me an error "joint position exceeding positive limit".
I've tried to sync kinematics by issuing M66 E0 L0 according to above attached links, but no luck, still no change.
Any idea on what else is missing?
  • Moderator
  • Moderator
24 Dec 2021 06:28 #229878 by tommylight
Replied by tommylight on topic [solved] change axis-limits through hal-pins
@szary11
No triple posting, makes it very hard to follow what has been answered and what not.
  • Aciera
  • Administrator
  • Administrator
24 Dec 2021 07:08 - 24 Dec 2021 07:09 #229882 by Aciera
You have to deal with 'axis'- AND 'joint'-limits.
Last edit: 24 Dec 2021 07:09 by Aciera.
24 Dec 2021 08:50 #229891 by szary11
@Aciera, many thanks for that! Indeed I had set up axis Z only, without joint. I will check if it works now
@tommylight, apologies. I was desperate to set the machine up before christmass! :)
Merry christmass gents!
Time to create page: 0.149 seconds
