Second LPT port - SOLVED!
- radek_marko
- Thank you received: 18
09 Apr 2020 19:18 #163382
by radek_marko
Second LPT port was created by radek_marko
I'm trying to add second LPT port connected to PCI.
The port is detected by lspci -v
If I'm selecting 1 port in conf then it all works, when I'm switching to 2 ports then the first port stops working
I've tried changing the base address of LPT1 in BIOS - it's the same for base address 0x378 and 0x278.
Any help would be appreciated.
02:02.0 Parallel controller: Device 1c00:2170 (rev 0f) (prog-if 01 [BiDir])
Subsystem: Device 1c00:2170
Flags: medium devsel, IRQ 11
I/O ports at bc00 [size=8]
I/O ports at b800 [size=8]
- Thank you received: 2162
09 Apr 2020 19:22 #163383
Replied by cmorley on topic Second LPT port
are you using 0 and 1 for port addres values in linuxcnc?
If linux detects the ports properly then that should work
- radek_marko
09 Apr 2020 20:23 #163387
by radek_marko
Replied by radek_marko on topic Second LPT port
On the first port, I was trying leaving as 0 and second port I have 1.
I've also tried 0x378 / 0x278 on the first port and 1 on the second, but no luck.
- radek_marko
09 Apr 2020 20:55 #163390
by radek_marko
How can I check "If linux detects the ports properly then that should work" - the tester I found for LPT port testing works only on LPT1
. Is there any option to test both ports?
I'm a newbie in the field - how can I check if the port is installed?
lspci -v shows that the card was detected - is that right?
09 Apr 2020 21:56 #163397
so one is onboard and one is PCI?
The onboard can be made to work but the pci doesn't (and infact stops the onboard)
Do I have that right?
I'm no expert on parports but that will help those who are.
- Thank you received: 7013
10 Apr 2020 00:21 #163416
Replied by tommylight on topic Second LPT port
In the hal file:
loadrt parport address "0x378, 0xbc00"
- radek_marko
10 Apr 2020 06:59 #163453
by radek_marko
so one is onboard and one is PCI? - correct
The onboard can be made to work but the pci doesn't (and infact stops the onboard) - correct. If in conf I will select a single port (with the second port still in PCI slot it works), when two parallel port selected the first stops working
- radek_marko
10 Apr 2020 08:58 #163461
by radek_marko
I did this test in the morning, but I think I might be doing things not 100% right
I'm attaching photos of my screen and changes in .hal (I'm not sure if in the correct one)
I have also found LPT tester, but it works only on LPT1, I've tried to add address as suggested, but it didn't work
- radek_marko
10 Apr 2020 10:13 #163467
by radek_marko
I've realized that my files were not uploaded due to the large size...
- radek_marko
11 Apr 2020 15:44 - 11 Apr 2020 16:49 #163629
by radek_marko
tommylight - Thank you very much for giving me the direction to follow. I've managed to test my LPT port, but I STILL CANNOT completelly fix the issue
Just to remind my situation:
I've downloaded the LPT tester - from this thread LPT tester .
Then I have changed the addressas Tommy suggested, but without any positive result then I have changed it toand it worked as per video in this link:
VIDEO
Then I moved to the config of LinuxCNC and I've put 0x278 as the address of the first parallel port and 0xb800 as the address of the second parallel port. The config is now able to move all step motors. To test 2nd LPT I've added the z-limit switch to be on this port and I'm getting an error when running LinuxCNC - see attached photo.
Any help would be massively appreciated as I know that the extension card works correctly.
I have also created a dual-port tester, might be useful for someone like me in the future (print screen below)
was the key for meloadrt parport address "0x378, 0xbc00"
lspci -v
loadrt parport cfg="0xbc00 out"
loadrt parport cfg="0xb800 out"
Last edit: 11 Apr 2020 16:49 by radek_marko.
Time to create page: 0.109 seconds
