What component to use for a pushbutton ( not toggle )
- Marcodi
- Thank you received: 13
12 Apr 2020 11:27 #163780
by Marcodi
What component to use for a pushbutton ( not toggle ) was created by Marcodi
I need to connect an arduino to my linuxcnc installation. I programmed and built everything. The only thing missing is i need to make a putton in pyvcp ( which i made ) and to connect this button to an output pin on my mesa board.
So far this seems all logic, only problem i encounter now is that i can not use toggle, as this button needs to be used as kind of a jog button, meaning signal on when pushed and remains to be pushed, and signal off on release of the button. What component can i use for this in linuxcnc?
Toggle gives me signal ON on first push, signal OFF on next push. That is not what i need. I need a continuous signal as long as the button is pressed ( just like a jog button for an axis)
(( project idea: these buttons are arrows for up and down af a probe module that is run from an arduino board. So i need just an active output on my mesa board. ))
- Thank you received: 7505
12 Apr 2020 11:52 #163786
Replied by tommylight on topic What component to use for a pushbutton ( not toggle )
Easiest way:
check the parallel port tester that is included with Linucnc, it has buttons that are active as long as they are pressed.
Start Linuxcnc from the menu, sample configurations>apps>parport
Chose one and click OK so it copies that to your configuration folder, close, then open with text editor from the configs folder.
- Thank you received: 4155
12 Apr 2020 11:57 #163790
Replied by rodw on topic What component to use for a pushbutton ( not toggle )
That is supported in pyvcp
linuxcnc.org/docs/2.4/html/hal_pyvcp.html#r1_6_3
- Marcodi
12 Apr 2020 13:17 #163801
by Marcodi
Replied by Marcodi on topic What component to use for a pushbutton ( not toggle )
Thanks rodw,
That is exactly what I want to do but it is the hal setup I don't know. Build the pyvcp i already worked out.
That pyvcp halpin needs to be connected to some HAL signal. That's the thing I don't know.
- Marcodi
12 Apr 2020 13:43 #163805
by Marcodi
The problem is that this app doesnt copy to the configuration folder, so i cant get into the editor. Any solution?
Thx
Easiest way:
Thx
12 Apr 2020 13:52 #163806
/usr/share/doc/linuxcnc/examples/sample-configs/apps/parport/
- Marcodi
12 Apr 2020 14:19 #163807
by Marcodi
thx, but that gives me the parport component.
So what does this mean that simple making a signal for example as the following will set my output on active when button gets pressed??? nothing else, no loadrt or addf?
net arrowup pyvcp.arrowupbutton => hm2_5i25.0.7i84.0.0.output-01
in combination with a pyvcp panel:
<pyvcp>
<button>
<halpin>"arrowupbutton"</halpin>
<text>"UP"</text>
</button>
</pyvcp>
<pyvcp>
<button>
<text>"UP"</text>
</button>
</pyvcp>
