[solved]scara-switch-kins
  • bkt
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 6 months ago - 6 years 5 months ago #166149 by bkt
[solved] scara-switch-kins was created by bkt
****these is the initial problem, plus modified kins give me other problem .... see my solution at the end****
Because my scara have motor of j0 and j1 in same location, i need to add some function for right foward and invers calc ..... using standard 2.8 linuxcnc rip-install all work good.
But I promised a video to dgarret so i've install switch kins and I copy that scarakins and add one pin and calc needed.
Original file here: github.com/LinuxCNC/linuxcnc/blob/dgarr/...nematics/scarakins.c
My file add pin for added reduction because belt from motor of j1 to real position of j1 and j1 adictional calc. No other. After there I ry to launch halcompile of modified scarakins.c (no change name ... but if I change it obtain the same error), and I have these error:
bkt@bkt-Demo1:~/linuxcnc-skins$ halcompile --compile '/home/bkt/linuxcnc-dgskins/scarakins.c' Compiling realtime scarakins.c Linking scarakins.so /usr/bin/ld:scarakins.ver:2: syntax error in VERSION script collect2: error: ld returned 1 exit status /home/bkt/linuxcnc-dgskins/src/Makefile.modinc:118: recipe for target 'scarakins.so' failed make: *** [scarakins.so] Error 1
not understand why really ..... because other rip-installa (standard linuxcnc-dev folder) work well.
Yeas I have 2 folder: linuxcnc-dev for rip-install of standard linuxcnc 2.8, an other folder linuxcnc-dgskins for dgarret fork switgh_kins rip-install ....
I don’t think the problem comes from my file. but the shape of the file is different from what I was used to ... so I can’t exclude it ... I attach it as it is ....
Warning: Spoiler!
thanks in advances for how can suggest me the problem ...
bkt
Last edit: 6 years 5 months ago by bkt.
6 years 6 months ago - 6 years 6 months ago #166155 by dgarrett
Replied by dgarrett on topic scara-switch-kins
I can reproduce the "VERSION script" error message using
halcompile -- but note that halcompile is primarily aimed at
making hal components from .comp files. Making a hal
component or a custom kinematics module from a .c file will
require additional work and maybe some undocumented methods.
I'm not familiar with the details to make halcompile work
for arbitrary c files implementing a kinematics module.
Instead (Method1), recommend to just copy over (replace) the
in-tree file in your rip-install, example:
$ cd src/emc/kinematics $ cp your_scarakins.c scarakins.c # replace in-tree file $ cd ../.. # src dir $ make && sudo make setuid
Alternatively (Method2), in the dgarr/s_kins branch on a RIP install
using rt-preempt, you can use the in-tree scarakins.c but
specify an additional user kinematics type as described in the
docs section on "User kinematics provisions".
See:
asciidoc: github.com/LinuxCNC/linuxcnc/blob/dgarr/...otion/switchkins.txt
html: www.panix.com/~dgarrett/stuff/switchkins.html
An example custom in-tree kinematics file is provided at
github.com/LinuxCNC/linuxcnc/blob/dgarr/...ematics/userkfuncs.c
So you could put your modified kinematics routines in a
similar file using the expected and required function naming
(userkKinematicsSetup, userkKinematicsForward,
userkKinematicsInverse) and invoke make as described in the
docs:
$ userkfuncs=/home/myname/kins/mykins.c make && sudo make setuid
With this method, the kinematics types available when loading
scarakins will be:
type0: in-tree scarakins
type1: identity
type2: your-user-custom-kins
A third method (Method3) would be to add your custom kinematics file
(with a unique name like myscarakins.c) to
the src/emc/kinematics directory and modify the src/Makefile
following the pattern used for other kinematics modules.
Last edit: 6 years 6 months ago by dgarrett.
6 years 6 months ago - 6 years 6 months ago #166182 by dgarrett
i did some more tests and see that you can use halcompile for the
scarakins.c in the master branch but not in the s_kins branch
-- the latter links in several object modules besides scarakins.o
i've looked at it a bit -- halcompile and/or src/Makefile.inc would
need some serious work to handle the multiple object files that
are used in the s_kins branch i think.
i recommend the methods mentioned earlier using make.
The following user(s) said Thank You: bkt
  • bkt
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 6 months ago #166190 by bkt
Replied by bkt on topic scara-switch-kins
On the mailing I asked andy to insert s_kins in the next master .... obviously there is work to do here .... I would be happy to continue this, obviously for now on a separate branch on github, although I know that I will have to delegate a lot to collaborators because I have difficulty, because of my job, to find the time to make some healthy sleep.
In any case, I too had thought of replacing the kinematics and compiling again .... but I needed confirmation, I have not studied the / blob / dgarr / s_kins / branch well yet ... in fact you have never answered me.
So I ask you here for permission to work on it. I don't like to take and run. I don't think anyone will take me to the FBI :laugh: (from the movie "Catch Me If You Can" 2001).
  • bkt
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 6 months ago #166191 by bkt
PLUS I use version of 20-03-2020 ... i need to download last one or is the same?
bkt
  • bkt
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 5 months ago - 6 years 5 months ago #167881 by bkt
Sorry DGarret ... but I ry to start My Scara machine ... Axis interface start right, I can move joint before homing, I can make homing in a right way but when homing end -> Y axis show on screen 360 instead 0 (0mm is correct, 360 is wrong), X axis show 1267 (these is ok), Z axis show 2000 (these is right), A B and C show the correct value = 0 ... than machine goes in following error of 0 and 3 joint ... I think because wrong value of Y axis .... not understand. These is mine X axis declaration in Hal file:
#******************* # AXIS X #******************* setp pid.x.Pgain [JOINT_0]P setp pid.x.Igain [JOINT_0]I setp pid.x.Dgain [JOINT_0]D setp pid.x.bias [JOINT_0]BIAS setp pid.x.FF0 [JOINT_0]FF0 setp pid.x.FF1 [JOINT_0]FF1 setp pid.x.FF2 [JOINT_0]FF2 setp pid.x.deadband [JOINT_0]DEADBAND setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT setp pid.x.error-previous-target true #setp pid.x.maxerror .0005 net x-index-enable <=> pid.x.index-enable net x-enable => pid.x.enable net x-pos-cmd => pid.x.command #mult2.0.in0 #setp mult2.0.in1 0.01 #net my-offset0 offset.0.offset <= mult2.0.out net x-vel-cmd => pid.x.command-deriv net x-pos-fb => pid.x.feedback net x-output => pid.x.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout0-scalemax [JOINT_0]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout0-minlim [JOINT_0]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout0-maxlim [JOINT_0]OUTPUT_MAX_LIMIT net x-output => hm2_5i25.0.7i77.0.1.analogout0 net x-pos-cmd joint.0.motor-pos-cmd net x-enable joint.0.amp-enable-out # enable _all_ sserial pwmgens net x-enable hm2_5i25.0.7i77.0.1.analogena # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.00.counter-mode 0 setp hm2_5i25.0.encoder.00.filter 1 setp hm2_5i25.0.encoder.00.index-invert 0 setp hm2_5i25.0.encoder.00.index-mask 0 setp hm2_5i25.0.encoder.00.index-mask-invert 0 setp hm2_5i25.0.encoder.00.scale [JOINT_0]ENCODER_SCALE net x-pos-fb <= hm2_5i25.0.encoder.00.position net x-vel-fb <= hm2_5i25.0.encoder.00.velocity net x-pos-fb => joint.0.motor-pos-fb #mux2.0.in0 net x-index-enable joint.0.index-enable <=> hm2_5i25.0.encoder.00.index-enable net x-pos-rawcounts <= hm2_5i25.0.encoder.00.rawcounts
after these joint.0 = X axis, joint.1 = Y axis, joint.2 = Z axis, joint.3 = A axis, joint.4 = B axis and joint.5 = C axis.
these problem came from confusion from C axis to joint.5 instead joint.3??
here the terminal error:
Found file(REL): ./n.hal Note: Using POSIX realtime !!! switchkins-type 0 is scarakins identityKinematicsSetup: coordinates:xyzc Joint 0 ==> Axis X Joint 1 ==> Axis Y Joint 2 ==> Axis Z Joint 3 ==> Axis C userkKinematicsSetup: emc/kinematics/userkfuncs.c <xyzc> max_joints=4 allow_duplicates=0 /* THESE CAN BE THE ERROR? I HAVE AND USE 6 AXSIS ANDA MAX JOINT = 4 ?? IN THESE CASE CORRECTION MAYBE KINEMATICS .. SEE END OF MESSAGES*/ ... ... ... hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort hm2/hm2_5i25.0: registered hm2_5i25.0: initialized AnyIO board at 0000:05:00.0 note: MAXV max: 1000.000 units/sec 60000.000 units/min note: LJOG max: 1000.000 units/sec 60000.000 units/min note: LJOG default: 10.000 units/sec 600.000 units/min note: AJOG max: 200.000 units/sec 12000.000 units/min note: AJOG default: 5.000 units/sec 300.000 units/min note: jog_order='XYZABC' note: jog_invert=set([]) following error axis 0 emc/task/taskintf.cc 947: Error on joint 0, command number 156 emc/task/taskintf.cc 947: Error on joint 3, command number 156 following error axis 3 following error axis 0 emc/task/taskintf.cc 947: Error on joint 0, command number 199 emc/task/taskintf.cc 947: Error on joint 3, command number 199 following error axis 3 following error axis 0 emc/task/taskintf.cc 947: Error on joint 0, command number 224 emc/task/taskintf.cc 947: Error on joint 3, command number 224 following error axis 3 Shutting down and cleaning up LinuxCNC... Running HAL shutdown script task: 12217 cycles, min=0.000007, max=0.064676, avg=0.010048, 0 latency excursions (> 10x expected cycle time of 0.010000s) hm2_5i25.0: dropping AnyIO board at 0000:05:00.0 hm2/hm2_5i25.0: unregistered RTAPI_PCI: Unmapped 65536 bytes at 0x7fcbef489000 hm2_pci: driver unloaded hm2: unloading Note: Using POSIX realtime
In your branch kins ( github.com/LinuxCNC/linuxcnc/blob/dgarr/...nematics/scarakins.c ) at row 217:
kp->required_coordinates = "xyzc"; kp->allow_duplicates = 0; kp->max_joints = strlen(kp->required_coordinates);
can be :
kp->required_coordinates = "xyzabc"; kp->allow_duplicates = 0; kp->max_joints = strlen(kp->required_coordinates);
these can work??
  • bkt
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 5 months ago - 6 years 5 months ago #168153 by bkt
Replied by bkt on topic [solved]scara-switch-kins
after the kind reply of dgarret, i copied his branch from github ... sorry i'm not practical and i don't have time ... so i made a new one in my github adding alter 3 scarakins ... scarakins4, scarakins10 and scarakins11. ... then I modified the makefile and some other points (the grep -Iri 'scarakins' 'path / s_kins' command helped me with this) .... then I committed my version and then downloaded and installed it. .. now my scara resets correctly even if I use 6 axes .... the problem was just that ... in order not to make a mistake I matched the joints and the kinematics (the C axis of the scara is now the joint [5 ] so that there is no sequence error in the XYZABC string) ... I have yet to start it at work, but at least it homing correctly. If then the rest is correct too .... I will make a nice video so as to honor a promise. I put the link to my github just verified that the download runs correctly. For now I am happy with this result.
*** ok it is working code for me pourpose ****
so promised link ... github.com/bkt-it/linuxcnc_s_kins_bkt
Thanks a lot for dgarret suggestion and works!!!
  • bkt
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 5 months ago #168198 by bkt
the short video of machinery ... note 2 added axis:
