5axiskins tool offset
2 years 11 months ago #286523 by Aciera
Replied by Aciera on topic 5axiskins tool offset
Please attach your hal file.
2 years 11 months ago #286702 by choqui2010
Replied by choqui2010 on topic 5axiskins tool offset
Hello, sorry for responding late, these days I was out of the machine.
I will attach the INI and HAL files
2 years 11 months ago #286703 by choqui2010
File Name: MARLON_2023-11-28.hal
File Size:4.4 KB
File Name: MARLON_2023-11-28.ini
File Size:3.34 KB
2 years 11 months ago #286716 by Aciera
Not sure where your error message comes from as '5axiskins.pivot-length' is not used in your hal file. Do you have anything in the 'custom.hal' file or something in the postgui hal files?
2 years 11 months ago #286798 by choqui2010
actually the message would be like this.
ERROR.!!
./MARLON.hal:113: Signal 'pivot-len' can not add I/O pin 'lupakins.pivot-length', it already has OUT pin 'pivotsun.out'
2 years 11 months ago #286799 by Aciera
the only line in your hal and ini that contains 'lupakins.pivot-length' is this one in your hal file, which seems to be the one it complains about.
net :pivot-len <= pivotsum.out => lupakins.pivot-length
This would suggest that you have some other hal file in your config folder that also contains a similar line. If you are unsure then please compress your entire machine config folder and post that here so I can have a look at all the files in the config.
Time to create page: 0.446 seconds
