5axiskins tool offset
6 years 5 months ago #168182 by AndrewL
Replied by AndrewL on topic 5axiskins tool offset
At some point, I don't know when, my 5axiskins stopped working properly. If I create a generic vismach 5axis bridge mill configuration the vismach simulation moves as you would expect but x (joint 0) and y (joint 1) are no longer are coordinated with C in 'AXIS'. Any suggestions as to where to find what went wrong?
At this time, I'm running linuxcnc-uspace-dev 1:2.8.0~pre1.5880.gef6ad1a on Debian Wheezy
2 years 11 months ago #286481 by choqui2010
Replied by choqui2010 on topic 5axiskins tool offset
Hello, were you able to solve the tool compensation issue in 5axiskins? I also find myself stuck there
2 years 11 months ago #286482 by Aciera
Replied by Aciera on topic 5axiskins tool offset
Have you setup your hal to add the tool_offset to the pivot length?
See '/axis/vismach/5axis/bridgemill/5axisgui.hal':
loadusr -W 5axisgui # to set different pivot_len, use: #   'loadusr -W 5axisgui pivot_len=value' net :jx  joint.0.pos-fb 5axisgui.jx net :jy  joint.1.pos-fb 5axisgui.jy net :jz  joint.2.pos-fb 5axisgui.jz net :jb  joint.3.pos-fb 5axisgui.jb net :jc  joint.4.pos-fb 5axisgui.jc net :jw  joint.5.pos-fb net :jy2 joint.6.pos-fb # Note: no joint or motor connections are used # for the w coordinate # compute pivot-length needed for 5axiskins # according to gui pivot_len and tool z offset loadrt sum2 names=pivotsum addf pivotsum servo-thread net :gui-pivot-len <= 5axisgui.pivot_len net :gui-pivot-len => pivotsum.in0 net :tool-len <= motion.tooloffset.z net :tool-len => pivotsum.in1 net :tool-len => 5axisgui.tool_length net :pivot-len <= pivotsum.out net :pivot-len => 5axiskins.pivot-length net :tool-diam <= halui.tool.diameter net :tool-diam => 5axisgui.tool_diam
2 years 11 months ago #286484 by choqui2010
Thank you very much for answering, Here is what I don't understand, in my model I don't get those configurations. In the configuration that you sent me, I understand that it is from a vismach and if I put it as it is in my hal file, it will not work, so what letters or parameters should I modify? (Please help, I am very new and forgive my English, I use Google Translate)
2 years 11 months ago #286486 by Aciera
You need to the lines for the kinematic component and set your pivot length:
loadrt sum2 names=pivotsum addf pivotsum servo-thread setp pivotsum.in0 <your pivot length here> net :tool-len <= motion.tooloffset.z => pivotsum.in1 net :pivot-len <= pivotsum.out => 5axiskins.pivot-length
2 years 11 months ago #286490 by choqui2010
ERROR.!!
./MARLON.hal:113: Signal 'pivot-len' can not add I/O pin '5axiskins.pivot-length', it already has OUT pin 'pivotsun.out'
