7i76e bitfile creation help needed
- atlantis
- Topic Author
6 years 5 months ago #167870
by atlantis
7i76e bitfile creation help needed was created by atlantis
Unfortunately I don't really find much info on writing bitfiles specifically for Mesa cards and it's quite some years since I last dealt with Xilinx stuff.
I want to connect my MPG pendant to expansion connector P1, all the signals. Therefore I need to modify the bitfile to map the encoder inputs to somewhere on P1. However I can't get it to compile without an error. So far I have modified these two lines:
and get an
error. Now when I change it to
it does compile but my guess is that if I put "00" these will be inputs for the main encoder (spindle) and not one of the additional encoders that are normally available on inputs 16-19 in mode 2. Is my guess correct and if it is, how do I get what I need?
Regards
Martin
IOPortTag & x"01" & QCountTag & QCountQAPin, -- I/O 25 PIN 5
IOPortTag & x"01" & QCountTag & QCountQBPin, -- I/O 26 PIN 6
and get an
ERROR:HDLCompiler:533 - "/home/ise/Xilinx/7i80/configs/hostmot2/source/hostmot2sp6.vhd" Line 1187: Index 1 is out of array constraint 0 downto 0 for target quada
IOPortTag & x"00" & QCountTag & QCountQAPin, -- I/O 25 PIN 5
IOPortTag & x"00" & QCountTag & QCountQBPin, -- I/O 26 PIN 6
Regards
Martin
- Thank you received: 5334
6 years 5 months ago - 6 years 5 months ago #167878
Replied by PCW on topic 7i76e bitfile creation help needed
In the module ID section you would need to change:
(QcountTag, x"02", ClockLowTag, x"01", QcounterAddr&PadT, QCounterNumRegs, x"00", QCounterMPBitMask),
to
(QcountTag, x"02", ClockLowTag, x"02", QcounterAddr&PadT, QCounterNumRegs, x"00", QCounterMPBitMask),
(this changes the number of encoder modules in the configuration)
Any reason you are not using the built-in 7I76E MPG counter inputs on field I/O 16..19?
to
Last edit: 6 years 5 months ago by PCW.
- atlantis
- Topic Author
6 years 5 months ago #168245
by atlantis
Replied by atlantis on topic 7i76e bitfile creation help needed
Thanks, this did the trick! Is there a tutorial available somewhere on modifiying these bitfiles? I did a lot of searching and didn't find anything that actually explains what means and does what exaxtly.
The reason is simply that I prefer to have all the mpg signals on one dedicated connector, I don't like the idea of wiring just the encoder wires over to another connector.
