2.8 5axiskins bug?
19 May 2020 12:37 #168287 by AndrewL
2.8 5axiskins bug? was created by AndrewL
In the current version of 2.8 (linuxcnc-uspace-dev 1:2.8.0~pre1.5880.gef6ad1a), if I use the LinuxCNC Configuration Selector, LinuxCNC/SIM/SIM/axis/vismach/5axis/bridgemill/5axis
to test the 5axiskins, I jog B, then attempt to jog C, but the machine will not rotate around the tool as expected.
If I do the same procedure in 2.7 (linuxcnc-uspace-dev 1:2.7.15.8.gf38f9c), the machine rotates around the tool.
Can anyone else confirm that this is a bug?
23 May 2020 03:58 #168666 by bbsr_5a
Replied by bbsr_5a on topic 2.8 5axiskins bug?
i dont see a bug in the movement
what are you expecting
the new interpreter from 2.8 dont like the INI format as it is not straight
here is a better ini to the Machine more speed and presetup
01 Jun 2020 07:20 #169660 by AndrewL
Replied by AndrewL on topic 2.8 5axiskins bug?
Thank you for your reply. I used your config without success on my computer. I've tried uninstalling and reinstalling linuxcnc. I've also tried on multiple computers. Prior to noticing this problem, I had been attempting to halcompile a switchkins config and had been experimenting with the locked rotary axis feature. Could this be the cause?
15 Jun 2020 23:29 #171816 by choqui2010
Replied by choqui2010 on topic 2.8 5axiskins bug?
I have a similar problem, when jogging the individual axes they are all ok but the moment you make a design the Y axis is reversed.
any suggestion?
16 Jun 2020 00:00 #171818 by Aciera
Replied by Aciera on topic 2.8 5axiskins bug?
@AndrewL
What do you mean by:
did you use halcompile to compile the kinematics file (.c)?
@choqui2010
What do you mean by "make a design"?
Time to create page: 0.174 seconds
