Going from XYZA to XYZBC
- Doug Crews
- Thank you received: 9
23 May 2020 17:35 #168731
by Doug Crews
Going from XYZA to XYZBC was created by Doug Crews
Hello All.
I’m trying to go from XYZA configured using Pnconf to XYZBC by editing the ini and hal files.
I’m only needing to do 3+2 milling. That is 3 + 2 indexing. My ini file doesn’t have a Kinematic section. Not sure if I need to make a change in that if I’m only doing 3 +2 indexing.
I’m using Axis Display and from the debug info that seems to be where the problem is located or somewhere around the trajectory section and only with the 5’th axis. I only changed the ini and hal files. I don’t know about changes that need be done to axis display.
If someone could point me to thread on this topic or, point to errors in my files it would be greatly appreciated
Thanks!
Thanks!
- Doug Crews
23 May 2020 22:25 #168760
by Doug Crews
Replied by Doug Crews on topic Going from XYZA to XYZBC
I finally landed on the correct search term. Thanks to an earlier reply by PCW problem solved.
Ini file
Axes = 6
Ini file
Axes = 6
Time to create page: 0.336 seconds
