Axis Interpolation in Trivial Kinematics
09 Jun 2020 09:28 #170838 by Ameone
Hi everyone,
I have a robotic arm with 5 axis/joints all defined as rotary in the .ini file. I'm currently using trivial kinematics so that I can directly specify the joint angles in the g-code file G1 X Y Z A B. Do you know how LinuxCNC handles the axis interpolation in this case? From what I've understood, LinuxCNC moves all axis so that the movement starts and stops at the same time. Is it correct? Moreover, how is the feedrate for each axis computed?
Thanks,
Amedeo
09 Jun 2020 10:44 #170840 by bbsr_5a
Replied by bbsr_5a on topic Axis Interpolation in Trivial Kinematics
if you go to G93 it can be calculatet at the TIME it needs to retch the point
some CAM system do this
if you do the ROBOT with the KINETICS tat is made for it like PUMA it will be this way so no need to interact by cam
WHY trivial kinetics if you got a Non Trivial mashine
09 Jun 2020 10:47 #170841 by Ameone
Replied by Ameone on topic Axis Interpolation in Trivial Kinematics
Ok thanks! We tried this approach because we wanted to handle the robot kinematics through a separate program (written in Matlab).
09 Jun 2020 10:55 #170843 by bbsr_5a
then you need mathlab to tell to output G93 calculated on the Distance to the Axis zero point
09 Jun 2020 11:02 #170844 by Ameone
Ok thanks again for the tip I'll try this solution!
10 Jun 2020 01:43 #170916 by bbsr_5a
here is a ready made code no need for headbang
www.ganotechnologies.com/cnc/rapidrotary/
10 Jun 2020 02:20 #170918 by Ameone
Thanks, pretty cool program!
10 Jun 2020 03:04 #170921 by bbsr_5a
NP
if you want to move your robot like it is to do in a coordinatesystem you shoudt go for PUMA_kins
see the SIM -> AXIS->vismach->puma Puma560 INI File
Time to create page: 0.094 seconds
