Laser setup 7i96
6 years 3 months ago - 6 years 3 months ago #175194 by mrmike
Laser setup 7i96 was created by mrmike
I have issues trying to set up a laser on a 7i96 board. I have an SSR turning on a relay to power the laser, and the PWM lead going to step+ lead on the step4 lead. I have the following statements in the hal file
net spindle-on spindle.0.on => hm2_7i96.0.ssr.00.out-02
net digital-out-0 motion.digital-out-00 => hm2_7i96.0.ssr.00.out-01
net spindle_speed spindle.0.speed-out hm2_7i96.0.pwmgen.00.value
setp hm2_7i96.0.pwmgen.00.output-type 1
setp hm2_7i96.0.pwmgen.00.scale [SPINDLE]MAX_RPM
setp hm2_7i96.0.pwmgen.pwm_frequency [SPINDLE]PWM_FREQUENCY
net spindle-enable hm2_7i96.0.pwmgen.00.enable
#net spindle-speed-out-rpm-abs hm2_7i96.0.pwmgen.00.value
and with halcmd show all |grep *pwm* I get
29 bit IN FALSE hm2_7i96.0.pwmgen.00.enable <== spindle-enable
29 float IN 0 hm2_7i96.0.pwmgen.00.value <== spindle_speed
==> hm2_7i96.0.pwmgen.00.enable
==> hm2_7i96.0.pwmgen.00.value
29 bit RW FALSE hm2_7i96.0.pwmgen.00.offset-mode
29 bit RW FALSE hm2_7i96.0.pwmgen.00.out0.invert_output
29 bit RW FALSE hm2_7i96.0.pwmgen.00.out0.is_opendrain
29 bit RW FALSE hm2_7i96.0.pwmgen.00.out1.invert_output
29 bit RW FALSE hm2_7i96.0.pwmgen.00.out1.is_opendrain
29 s32 RW 1 hm2_7i96.0.pwmgen.00.output-type
29 float RW 23000 hm2_7i96.0.pwmgen.00.scale
29 u32 RW 0x00004E20 hm2_7i96.0.pwmgen.pdm_frequency
29 u32 RW 0x00002710 hm2_7i96.0.pwmgen.pwm_frequency
hm2_7i96.0.pwmgen.00.out0.invert_output hm2_7i96.0.gpio.025.invert_output
hm2_7i96.0.pwmgen.00.out0.is_opendrain hm2_7i96.0.gpio.025.is_opendrain
hm2_7i96.0.pwmgen.00.out1.invert_output hm2_7i96.0.gpio.026.invert_output
hm2_7i96.0.pwmgen.00.out1.is_opendrain hm2_7i96.0.gpio.026.is_opendrain
If I place the PWM lead on the Srep4- lead, I get a laser output, but cannot seem to set it any lower than high power. I am using s100 m3 and the run the speed up to 10000, without any change in the laser level.
I am missing something. Any help would be appreciated.
Last edit: 6 years 3 months ago by mrmike.
6 years 3 months ago #175199 by PCW
Replied by PCW on topic Laser setup 7i96
Have you looked at the PWM pins when you have a say 1/2 way up setting?
Also you can measure the PWM duty cycle with a voltmeter since it will average
the PWM so 50% of full scale (11500 in your case) should read about 2.5V
from the STEP4+ pin to ground
6 years 3 months ago #175209 by mrmike
Replied by mrmike on topic Laser setup 7i96
hm2_7i96.pwmgen.00.value changes from 0 to one when I start the spindle hm2_7i96.pwmgen.00.enable stays at false.
I changed the net spindle-on spindle.0.on => hm2_7i96.0.ssr.00.out-02 to spindle enable to get the statement to go true. but the voltage on Step4+ stays at 5Vdc at s0.1 to s10000
I added the hal and ini files.
6 years 3 months ago - 6 years 3 months ago #175210 by PCW
Hmm, what firmware are you using?
Does setting the pwm.00.enable false make step4+ 0V?
mesaflash --device 7i96 --readhmid
Will read on the current pinout
Last edit: 6 years 3 months ago by PCW.
6 years 3 months ago #175211 by mrmike
I re-flashed the firmware and now see a difference in output of the laser. Thanks for the help
6 years 3 months ago #175212 by PCW
Ahh, you must have had firmware that had 5 stepgens on the 7I96 and a pwmgen on the expansion connector.
Time to create page: 0.361 seconds
