- Configuring LinuxCNC
- Advanced Configuration
- Carousel component- feature request. Please help andypugh!
- Henk
- Thank you received: 92
07 Aug 2020 14:34 #177643
by Henk
Carousel component- feature request. Please help andypugh! was created by Henk
Hi
I am retrofitting a Mitsui Seiki HR5 machining centre.
The ATC use 2 proximity sensors labeled A and B and an additional reference proxy for homing. The A and B proxy's switch on and off by reading the same trigger plate on the ATC chain in such a way that it produces a quadrature signal when the ATC rotates. The (any) tool pocket is in the correct position when both A and B signals are on. Rotating slightly fwd or backw, causes either one of these two signals to go off.
Problem. The carousel comp encoding schemes currently available does not cater for this. The closest match is Index mode. I got it working by using only the A signal and the reference signal in index encoding mode. This is working but I had to add some logic when the ATC rotates in reverse because it stops slightly out of position due to approaching the striker from the other side.
Not sure what will be the easiest solution here?
Maybe the the easiest would be to and2 the and B signals and use that instead of only A?
Or maybe add this encoding scheme to the comp?
Video here
Advice is always appreciated.
Video here
- Thank you received: 7505
07 Aug 2020 14:43 #177644
Replied by tommylight on topic Carousel component- feature request. Please help andypugh!
I am not Andy, but i will give it shot as you are very close:
signal A input >>> and2.0-in1
signal B input >>> and2.0-in2
and2.0-out >>> carousel input
That would be a rough direction, also loadrt and addf lines for and2 have to be add to the hal file.
- Henk
07 Aug 2020 14:56 #177646
by Henk
Replied by Henk on topic Carousel component- feature request. Please help andypugh!
Hi Tommy
I am going to try that. Concern is that it will overshoot the position. Not sure what will happen in that case....try and see....
- kris321
- Visitor
01 Sep 2020 05:48 - 01 Sep 2020 05:54 #180304
by kris321
My husband had the same problem, did you find a solution?
Replied by kris321 on topic Carousel component- feature request. Please help andypugh!
Hi
The ATC use 2 proximity sensors labeled A and B and an additional reference for homing. The A and B proxy's switch on and off by reading the same trigger plate on the ATC chain in such a way that it produces a quadrature signal when the ATC rotates. The (any) tool pocket is in the correct position when both A and B signals are on. Rotating slightly fwd or backw, causes either one of these two signals to go off.
Video here
Last edit: 01 Sep 2020 05:54 by tommylight. Reason: removed spam
01 Sep 2020 05:55 #180306
kris321 Has left the building !
Oh i was waiting and waiting and then it happened, link embedded in Henk's message!
Time to create page: 1.035 seconds
