Create a ini file
- Profed81
- Visitor
22 Sep 2020 22:52 #183387
by Profed81
Create a ini file was created by Profed81
How can I create a configuration file for a machine without any base configuration? That is, without using any assistant or example?
- Thank you received: 7505
23 Sep 2020 04:11 #183436
Replied by tommylight on topic Create a ini file
Can not think of a reason why would you want to do that but here is a rough idea:
-create a hal file containing loadrt for real time stuff and parallel port or mesa boards, servo period timing and/ or base period, addf stuff to those periods together with reads and writes, add I/O, add stpegens or PID's, arrange the stepgens and PID's to read the initial values form the INI file, add corresponding entries to the ini file, add the display and hal and traj and axis and toolchange and...... stuff to the ini file.
Pretty sure i forgot something.
- BeagleBrainz
- Visitor
23 Sep 2020 04:33 #183437
by BeagleBrainz
Use a text editor ?
Replied by BeagleBrainz on topic Create a ini file
Use a text editor ?
- Thank you received: 4155
23 Sep 2020 04:42 #183439
Replied by rodw on topic Create a ini file
I have never used an assistant of any kind to build my machine'sconfig.
But I did borrow a config on the forum here to act as a guide to start with.
23 Sep 2020 07:17 #183462
I knew it !
Use a text editor ?
Time to create page: 1.011 seconds
