switchkins install advice
6 years 4 weeks ago #184665 by Mkcherni
Replied by Mkcherni on topic switchkins install advice
Ok success.
The cause of my problem was that i cut and paste the text from tutorial to the terminal. t
The line cd linuxcnc-dev/debian did not change the directory to debian. I had to separate the 2 by typing cd linuxcnc-dev then cd debian. Then everything worked as instructed.
6 years 4 weeks ago #184669 by Mkcherni
That is very very very cool big big thank you to all who developed this. I would never have thought this was possible at a hobby level. Amazing
  • Profed81
  • New Member
  • New Member
5 years 11 months ago #190820 by Profed81
Replied by Profed81 on topic switchkins install advice
I do not understand how it could work, because the switchkins is for a tilt table, and your machine is a tilt spindle
5 years 11 months ago #190838 by Aciera
Replied by Aciera on topic switchkins install advice
"switchkins" is NOT limited to any particular machine kinematics. Its LinuxCNC with the ability to switch the type of kinematic from within the gcode.
  • Profed81
  • New Member
  • New Member
5 years 10 months ago #190840 by Profed81
Replied by Profed81 on topic consejos de instalación de llaves
What parameters should be adjusted for each machine?
5 years 10 months ago #190844 by Aciera
Not quite sure what you mean. If you want to switch the kinematics when using the switchkins branch you have to build it
www.panix.com/~dgarrett/stuff/s_kins_guide.txt
and then you can use M commands to switch the kinematics you have set up.
www.panix.com/~dgarrett/stuff/switchkins.html
Time to create page: 0.181 seconds
