Howto Control 4 Motors Per Z-Axis
- Bari
- Thank you received: 234
13 Oct 2020 01:22 - 13 Oct 2020 01:35 #185923
by Bari
Howto Control 4 Motors Per Z-Axis was created by Bari
Any thoughts on how to control 4 motors on a z-axis as in the machine in the picture?
www.3dprintingmedia.network/wp-content/u...79B30-1832x1374.jpeg
forum.linuxcnc.org/49-basic-configuratio...ltiple-slaves#160750 has a config for 4 motors on a Z-axis but I don't believe they are also controlling XY at the same time.
2.8 allows for 2 joints per axis. How to handle 4 joints per axis with a 3 axis platform that with only 1 motor per axis and would normally use simple kinematics?
Last edit: 13 Oct 2020 01:35 by Bari. Reason: added more info
- Thank you received: 7505
13 Oct 2020 01:31 #185924
Replied by tommylight on topic Howto Control 4 Motors Per Z-Axis
Have a look at a tandem axis in hal add stepgens or pids and feedback as any other joint/axis, then in the ini file under the Z axis section add all 4 joints. Also in the ini file under the display ( not sure this is needed but it is there) section add XYZZZZ and same for traj section, and edit the number of joints.
That should work.
That should work.
The following user(s) said Thank You: Bari
- Thank you received: 1482
13 Oct 2020 07:58 #185977
Replied by Todd Zuercher on topic Howto Control 4 Motors Per Z-Axis
Agree, I don't think there is any limit to the number of joints that can be assigned to an axis, other than the maximum total number of joints available (16).
Looks like a fun machine. You should share some of your creations, once you've perfected it.
- Bari
13 Oct 2020 19:24 #186045
by Bari
Replied by Bari on topic Howto Control 4 Motors Per Z-Axis
Sand casting printers for metals (Al, Fe, Steels, etc) and glass.
- Thank you received: 4155
14 Oct 2020 05:23 #186084
Replied by rodw on topic Howto Control 4 Motors Per Z-Axis
I did not think there was any limit to the number of joints (motors) on a single axis. Certainly none of the docs for 2.8 say its limited to two joints.
linuxcnc.org/docs/2.8/html/config/ini-ho...l#sec:homing-section
- Bari
14 Oct 2020 12:18 #186109
by Bari
It was just the way it was talked about that 2.8 now supports gantries that use 2 motors, when in fact it supports more than just 2.
Time to create page: 0.207 seconds
