XYZZBC-trt-kins module
- kimachren
02 Nov 2020 13:46 #188142
by kimachren
XYZZBC-trt-kins module was created by kimachren
Hello,
I have desperately been trying to build a custom version of xyzbc-trt-kins with double Z. After having fought with getting a working halcompile, I ended up with an error like Undefined symbol "map_coordinates_to_jnumbers" when starting Linuxcnc. Could somebody be so kind and make a working kins module for me? My build is the latest Stretch found on buildbot (2.8.0.98 preemtrt).
- Thank you received: 2177
03 Nov 2020 00:42 #188178
Replied by Aciera on topic XYZZBC-trt-kins module
I don't think you need a custom kinematics module at all as the Z is already being calculated in the existing kinematic.
Have you tried to add the second Z as a dual motor in the INI like a gantry?
Maybe you can get something out of this:
forum.linuxcnc.org/49-basic-configuratio...l-motor-gantry#86933
- kimachren
03 Nov 2020 01:30 #188184
by kimachren
Replied by kimachren on topic XYZZBC-trt-kins module
The machine runs fine with trivkins. But I need TCP, so xyzbc-trt-kins is needed. When I change from trivkins -> xyzbc-trt-kins in .ini and .hal, only one Z-motor runs with Z jogging. When jogging B, the other will run.
In the [KINS] section, the "coordinates" is "XYZZBC"
03 Nov 2020 01:48 #188185
So I think it's a problem of joint numbering as I don't think the kinematic needs to handle the dual motor. I could be wrong though.
Can you post your hal and ini files?
- kimachren
03 Nov 2020 01:55 #188187
by kimachren
Actually I read in some other thread that the kins indeed must be modified to accept a dual motor axis. So I don't know..
The files are coming soon
- kimachren
03 Nov 2020 02:03 - 03 Nov 2020 02:05 #188188
by kimachren
These are the files as they were yesterday.
Edit: I noticed that the .hal has xyzzbc-trt-kins (my custom ver.), but it didn't work with the original either.
Last edit: 03 Nov 2020 02:05 by kimachren.
03 Nov 2020 02:32 #188191
After a cup of coffee I've also changed my mind about this.
03 Nov 2020 02:42 - 03 Nov 2020 03:01 #188192
In your INI I don't see the dual motor setup as in a gantry. To pair a second motor wouldn't you define the HOME_SEQUENCE with a negative sign as in the config in the thread I referred to in my first post?
[edit]
Realized that really I have not much of a clue about the pairing of motors. So I should probably do some homework first. : LOL:
# Axis Y
[AXIS_Y]
MIN_LIMIT = -1.0
MAX_LIMIT = 715.0
MAX_VELOCITY = 100.0
MAX_ACCELERATION = 750.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
STEPGEN_MAXACCEL = 937.5
SCALE = 133.333333333
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -1.0
MAX_LIMIT = 715.0
HOME_SEARCH_VEL = -25.00000
HOME_LATCH_VEL = 0.500000
HOME_FINAL_VEL = 2.500000
HOME_IGNORE_LIMITS = YES
HOME_OFFSET = -2.0
# ---negative sequence number ensures both Y joints
# wait to back off the HOME_OFFSET simultaneously---
HOME_SEQUENCE = -1
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -1.0
MAX_LIMIT = 715.0
HOME_OFFSET = -2.0
HOME_SEQUENCE = -1[edit]
Last edit: 03 Nov 2020 03:01 by Aciera.
- kimachren
03 Nov 2020 03:00 #188195
by kimachren
I will have to disagree on the HOME_SEQUENCE as it has worked just fine with both Z's having home_seq 0 for a few years now ( with trivkins).
Copied from documentation:
"Used to define a multi-axis homing sequence HOME ALL and enforce homing order (e.g., Z may not be homed if X is not yet homed). An axis may be homed after all axes with a lower HOME_SEQUENCE have already been homed and are at the HOME_OFFSET. If two axes have the same HOME_SEQUENCE, they may be homed at the same time. If HOME_SEQUENCE is -1 or not specified then this joint will not be homed by the HOME ALL sequence. HOME_SEQUENCE numbers start with 0 and there may be no unused numbers."
03 Nov 2020 04:24 #188199
Yes, this thing with the negative number for the home sequence apparently is needed for the homing process. That is then unrelated, sorry about that.
I have successfully modified the trt-kins in the past to substitute the C axis for a trivial U axis. But I fear it was a rather fumbling and stumbling affair.
Maybe somebody will come along who actually knows what to do.
Time to create page: 0.761 seconds
