Encoder Spindle Index not working
- Josemmrosa
05 Nov 2020 09:46 #188402
by Josemmrosa
Encoder Spindle Index not working was created by Josemmrosa
I am struggling trying to setup spindle encoder on a converted manual lathe. I am using a 5i25+7i76 combo.
I need to know the rpm and have a starting point to make threads (G76 syncro motion) . The A and B channel seems to be working fine, setting low pass filter gain small, aprox 0.03, with these value RPM remains stable. Wired Z and Z/ channel to IDX+ and IDX- pins of the 7i76 but turning lathe chuck by hand spindle index signal never change from false to true in a complete turn in hal meter. The encoder P/N is SICK DBS50E-S5AK01000. I am stuck and will appreciate any help.
Thank you.
José
Thank you.
José
- Thank you received: 5337
05 Nov 2020 10:21 #188405
Replied by PCW on topic Encoder Spindle Index not working
I would not expect to see the index signal with halshow (its typically
too short to see unless you turn the spindle _very_ slowly)
The way to check index operation is to:
sets [index_enable_signal] true
Then monitor [index_enable_signal] with halshow as you slowly
rotate the spindle. If index is working, [index_enable_signal]
should go false at the index location.
[index_enable_signal] may have different names depending on how
the hal file was created
Time to create page: 0.090 seconds
