- Configuring LinuxCNC
- Advanced Configuration
- xyzbc-trt-kins and linuxcnc 2.9 (map_coordinates_to_jnumbers)
- sd
12 Nov 2020 07:45 #189107
by sd
xyzbc-trt-kins and linuxcnc 2.9 (map_coordinates_to_jnumbers) was created by sd
Im Having difficulties implimenting xyzbc-trt-kins on Debian Debian GNU/Linux 9.12 (stretch) 9.12 stretch with linuxcnc-uspace 1:2.9.0~pre0.2245.g09397b8d3
After compiling the kins file and editing the halfile and ini files i am getting an error of ;
Debug file information:
Note: Using POSIX realtime
xyzbc-trt-kins: dlopen: /usr/lib/linuxcnc/modules/xyzbc-trt-kins.so: undefined symbol: map_coordinates_to_jnumbers
./xyzbcdef.hal:4: waitpid failed /usr/bin/rtapi_app xyzbc-trt-kins
./xyzbcdef.hal:4: /usr/bin/rtapi_app exited without becoming ready
./xyzbcdef.hal:4: insmod for xyzbc-trt-kins failed, returned -1
I have gone around in circles editing joint numbers, defining joints as as x=0,y=1,z=2,b=4,c=5 and x=0,y=1,z=2,b=3,c=4 and x=-1,y=-1,z=-1,b=3,c=4 (ive tried allsorts and probably completely ruined my machine setup but that can be fixed once ive figured out the problem!)
Is this likely a problem with using debian stretch or linuxcnc v 2.9?
Or am i being such a beginner that I have missed something obvious! I get that its trying to call something to do with the joints / joint numbers that is not there but im not proficient enough with computer programming to debug (i can write a cnc prog though!)
any help much appreciated!!
tia
stefan
tia
stefan
- Thank you received: 2177
12 Nov 2020 08:31 - 12 Nov 2020 08:34 #189109
There seems to be some confusion about an A axis:
Do you need an A axis?
Replied by Aciera on topic xyzbc-trt-kins and linuxcnc 2.9 (map_coordinates_to_jnumbers)
Did you use halcompile for that or recompile from source (make)? What do you need to change in the kinematics?After compiling the kins file
[KINS]
KINEMATICS = xyzbc-trt-kins coordinates = XYZABC
#This is a best-guess at the number of joints, it should be checked
JOINTS = 5pos->a = 0;#define REQUIRED_COORDINATES "XYZABC"Do you need an A axis?
Last edit: 12 Nov 2020 08:34 by Aciera.
- sd
12 Nov 2020 08:49 #189114
by sd
Replied by sd on topic xyzbc-trt-kins and linuxcnc 2.9 (map_coordinates_to_jnumbers)
I used halcompile.
No I dont need an a axis, this is where my confusion arrises! When i was originally setting up with trivkins it required 6 axis so i have tried every combination of 5 and 6 axis (xyzabc / xyzbc and edited hal to suit)
I was also looking in the xyzbc-trt-kins file at the joint assignments;
// joint number assignments
static int JX = -1;
static int JY = -1;
static int JZ = -1;
static int JB = -1;
static int JC = -1;
I tried editing these to correspond to the joint numbers but that also made no difference (im now thinking these are something to do with the inverse kinematics!?)
My google search led me to believe that maybe an undefined symbol as per the line ;
means its trying to call a label or variable or something that hasnt been called or defined yet maybe? am i on the right lines?
Thank you for your reply really appreciated!
static int JX = -1;
static int JY = -1;
static int JZ = -1;
static int JB = -1;
static int JC = -1;
12 Nov 2020 09:25 #189115
1. Halcompile does not work if external modules are required to compile the file. To compile xyzbc-trt-kins.c you would need to build from source as you would to install a RIP (Run in place) installation.
2. Why don't you just use the kinematics as it comes with every LinuxCNC install? There is a simulation in sim/axis/vismach/5axis/table-rotary-tilting. Call that up and you get a folder containing xyzbc-trt.ini in your configs. Then have a look how to define the joints and axis.
- sd
12 Nov 2020 10:50 #189125
by sd
Ive had a look at the sim/axis/vismach/5axis/table-rotary-tiltin and got the sim working for xyzac although im still getting the same error for xyzbc! Not seeing any tool point rotations although i will have to look at it further i think my brain has had enough for today
What im hoping to do is use my little 5 axis mill in a similar format to the heidenhain 5 axis i have used in the past. As in being able to rotate the bc or ac axis and have xyz transform to suit and still be able to program xyz according to the plane I am working on, i figured this would be better than having to create a post including all the transformations and enable me to manually program if required - probably going to use far more 3+2 than 5 axis but would still like to be able to compensate for a part/tool offset.
Im probably biting off more than I can chew but after 20 years as a machinist I couldn't go down the route of a 3 axis router wheres the fun in that!
Thank you for your help I will have a look into the vismach sim and doing build from source or build i place
Thanks again
stefan
Thanks again
stefan
12 Nov 2020 12:30 #189141
I imagine you would have to reinstall LinuxCNC again since the xyzbc-trt-kin that is called up in the sim is the same corrupted file that didn't work with your own config.
Time to create page: 0.080 seconds
