Dual gantry stepper homing with uneven switches
5 years 11 months ago #190487 by Lunkwill
I have a dual stepper gantry on joints 0 and 3, and it's been homing great using a single switch netted to both joints. Tonight I added a limit switch on the other end of the gantry so it can automatically square the gantry, so now joint 0 and joint 3 have separate homing switches.
The joint 3 switch closes about ~0.020" before joint 0, and I think what's happening is that joint 3 starts backing up even though joint 0 is still creeping forward to hit its switch, so bad grindy things happen that weren't happening before. Does that sound plausible?
5 years 11 months ago #190495 by Clive S
Lunkwill wrote: I have a dual stepper gantry on joints 0 and 3, and it's been homing great using a single switch netted to both joints. Tonight I added a limit switch on the other end of the gantry so it can automatically square the gantry, so now joint 0 and joint 3 have separate homing switches.
Can you post your hal and ini files. Do you have the same -ve sequence value for joint 0 and 1?
5 years 11 months ago #190543 by Lunkwill
Here you go. Do you mean the HOME_SEARCH_VEL and HOME_LATCH_VEL? Yep, those are the same for both of the gantry joints.
5 years 11 months ago - 5 years 11 months ago #190549 by Mud
It's HOME_SEQUENCE that needs setting up.
edit: pulling from memory, so best you find the relevant bit in the documentation, but here are the joints for mine (0 and 1 are the gantry).
[AXIS_X] MIN_LIMIT = -90 MAX_LIMIT = 1000 # set to double the value in the corresponding joint MAX_VELOCITY = 500.0 # set to double the value in the corresponding joint MAX_ACCELERATION = 2000.0 # shares the above two equally between the joint and the offset OFFSET_AV_RATIO = 0.5 [AXIS_Y] MIN_LIMIT = -90 MAX_LIMIT = 760 # set to double the value in the corresponding joint MAX_VELOCITY = 500.0 # set to double the value in the corresponding joint MAX_ACCELERATION = 2000.0 # shares the above two equally between the joint and the offset OFFSET_AV_RATIO = 0.5 [AXIS_Z] MIN_LIMIT = -94 #reduced from -100 MAX_LIMIT = 10 # set to double the value in the corresponding joint MAX_VELOCITY = 200.0 # set to double the value in the corresponding joint MAX_ACCELERATION = 2000.0 # shares the above two equally between the joint and the offset OFFSET_AV_RATIO = 0.5 [JOINT_0] AXIS = X MIN_LIMIT = -90 MAX_LIMIT = 1000 MAX_VELOCITY = 250 MAX_ACCELERATION = 1000 TYPE = LINEAR SCALE = 50.929581789 STEPGEN_MAX_VEL = 300.0 STEPGEN_MAX_ACC = 2400.0 FERROR = 0.05 MIN_FERROR = 0.01 DIRSETUP = 20000 DIRHOLD = 20000 STEPLEN = 5000 STEPSPACE = 5000 DEADBAND = 0 P = 1000 I = 0 D = 0 FF0 = 0 FF1 = 1 FF2 = 0.00013 BIAS = 0 MAX_OUTPUT = 0 MAX_ERROR = 0.0127 HOME = 0 HOME_OFFSET = -100 HOME_SEARCH_VEL = -100 HOME_LATCH_VEL = -10 HOME_SEQUENCE = -1 HOME_USE_INDEX = False HOME_IGNORE_LIMITS = True [JOINT_1] AXIS = X MIN_LIMIT = -90 MAX_LIMIT = 1000 MAX_VELOCITY = 250 MAX_ACCELERATION = 1000 TYPE = LINEAR SCALE = 50.929581789 STEPGEN_MAX_VEL = 300.0 STEPGEN_MAX_ACC = 2400.0 FERROR = 0.05 MIN_FERROR = 0.01 DIRSETUP = 20000 DIRHOLD = 20000 STEPLEN = 5000 STEPSPACE = 5000 DEADBAND = 0 P = 1000 I = 0 D = 0 FF0 = 0 FF1 = 1 FF2 = 0.00013 BIAS = 0 MAX_OUTPUT = 0 MAX_ERROR = 0.0127 HOME = 0 HOME_OFFSET = -100 HOME_SEARCH_VEL = -100 HOME_LATCH_VEL = -10 HOME_SEQUENCE = -1 HOME_USE_INDEX = False HOME_IGNORE_LIMITS = True [JOINT_2] AXIS = Y MIN_LIMIT = -90 MAX_LIMIT = 760 MAX_VELOCITY = 250 MAX_ACCELERATION = 1000 TYPE = LINEAR SCALE = 50.929581789 STEPGEN_MAX_VEL = 300.0 STEPGEN_MAX_ACC = 2400.0 FERROR = 0.05 MIN_FERROR = 0.01 DIRSETUP = 20000 DIRHOLD = 20000 STEPLEN = 5000 STEPSPACE = 5000 DEADBAND = 0 P = 1000 I = 0 D = 0 FF0 = 0 FF1 = 1 FF2 = 0.00013 BIAS = 0 MAX_OUTPUT = 0 MAX_ERROR = 0.0127 HOME = 0 HOME_OFFSET = -100 HOME_SEARCH_VEL = -100 HOME_LATCH_VEL = -10 HOME_SEQUENCE = 1 HOME_USE_INDEX = False HOME_IGNORE_LIMITS = True [JOINT_3] AXIS = Z MIN_LIMIT = -94 MAX_LIMIT = 10 MAX_VELOCITY = 100 MAX_ACCELERATION = 1000 TYPE = LINEAR SCALE = 400 STEPGEN_MAX_VEL = 120.0 STEPGEN_MAX_ACC = 1200.0 FERROR = 1 MIN_FERROR = 1 DIRSETUP = 20000 DIRHOLD = 20000 STEPLEN = 5000 STEPSPACE = 5000 DEADBAND = 0 P = 1000 I = 0 D = 0 FF0 = 0 FF1 = 1 FF2 = 0.00013 BIAS = 0 MAX_OUTPUT = 0 MAX_ERROR = 0.0127 HOME = 0 HOME_OFFSET = 20 HOME_SEARCH_VEL = 100 HOME_LATCH_VEL = 10 HOME_SEQUENCE = 0 HOME_USE_INDEX = False HOME_IGNORE_LIMITS = True
Last edit: 5 years 11 months ago by Mud.
5 years 11 months ago #190552 by Lunkwill
I see you have them set to -1, which the docs say means that joint won't be homed at all. Is it a magic value in the case of dual axes that causes it to do the right thing?
5 years 11 months ago #190555 by Mud
Time to create page: 0.065 seconds
