Correcting axis bend with custom component and HAL
- tpmagda12
- Thank you received: 3
06 Dec 2020 20:54 - 08 Dec 2020 12:12 #191290
by tpmagda12
Correcting axis bend with custom component and HAL was created by tpmagda12
Another 'i cant build straight things' thread!
I recently built a large cnc router (10ft x 4ft) out of steel which required a lot of welding. Unfortunately the welding cause some warping of the Y axis leading to a bit of an irregular curve along the entirety of the Y axis. Although this was concerning i figured it could be compensated for with some good ol fashioned math.
I found two other threads that tried to tackle the same problem:
forum.linuxcnc.org/10-advanced-configura...-correct-axis-errors
forum.linuxcnc.org/10-advanced-configura...on-with-2-7-11#99833
This lead me to create a component as proposed by pgf and Andy Pugh that looks like this
I compiled this without issue and hooked her up to the existing x-pos-cmd and y-pos-cmd and the output was as desired for both x-out and x-comp when looking at the pins and signals using HAL configuration in AXIS.py
im running into issues when trying to translate this new value into actual motion, im struggling with the actual HAL config to get this to work. initially i tried to just correct if from custom.hal but kept getting all sorts of weird joint following errors (stepper motors). i messed around a lot with trying all sorts of different things but the closest i got to getting it to work was the following in my custom.hal
most of this i stole from my HAL file generated by pncconfig and i just inserted it into my custom.hal and removed it from my machine.hal
at machine start this causes both the x and tandem x axis to rotate very quickly about 10 degrees back and forth for about 4 seconds getting smaller with each perturbation until it settles. after it settles it, when i jog the y axis the x axis seems to compensate in AXIS.py but it doesn't seem the motors are actually moving in the real world. I think my error lies somewhere in not really understanding the difference between the following
i've tried many different variations of the above and still cant seem to get it to work
this is using a Mesa_7i96 if some of the config stuff looks different than what some others have.
free beer for any insight!
component y_axis_compensation
license "GPL"; // GPL v2 or later
option singleton yes;
pin in float x-in;
pin in float y-in;
pin out float x-out;
pin out float x-comp;
function cmd;
#include <rtapi_math.h>
FUNCTION(cmd){
x_comp = - 0.00000000013935308593 * pow(y_in,6) + 0.00000000872640918408 * pow(y_in,5) + 0.00000013374878613596 * pow(y_in,4) - 0.0000118495699768482 * pow(y_in,3) - 0.000112795225635197 * pow(y_in,2) + 0.00665520947546411 * y_in + 0.00876671144656871;
x_out = x_comp + x_in;
}I compiled this without issue and hooked her up to the existing x-pos-cmd and y-pos-cmd and the output was as desired for both x-out and x-comp when looking at the pins and signals using HAL configuration in AXIS.py
net x-pos-cmd => y-axis-compensation.x-in
net y-pos-cmd => y-axis-compensation.y-inim running into issues when trying to translate this new value into actual motion, im struggling with the actual HAL config to get this to work. initially i tried to just correct if from custom.hal but kept getting all sorts of weird joint following errors (stepper motors). i messed around a lot with trying all sorts of different things but the closest i got to getting it to work was the following in my custom.hal
loadrt y_axis_compensation
addf y-axis-compensation.cmd servo-thread
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
net x-output <= hm2_7i96.0.stepgen.00.velocity-cmd
net x-pos-fb <= hm2_7i96.0.stepgen.00.position-fb
net x-pos-fb => y-axis-compensation.x-in
net x-pos-comp y-axis-compensation.x-out => joint.0.motor-pos-fb hm2_7i96.0.stepgen.00.position-cmd
net x-enable <= joint.0.amp-enable-out
net x-enable => hm2_7i96.0.stepgen.00.enable
net x2-pos-cmd <= joint.1.motor-pos-cmd
net x2-vel-cmd <= joint.1.vel-cmd
net x2-output <= hm2_7i96.0.stepgen.01.velocity-cmd
net x2-pos-fb <= hm2_7i96.0.stepgen.01.position-fb
net x-pos-comp => joint.1.motor-pos-fb hm2_7i96.0.stepgen.01.position-cmd
net x2-enable <= joint.0.amp-enable-out
net x2-enable <= joint.1.amp-enable-out
net x2-enable => hm2_7i96.0.stepgen.01.enablemost of this i stole from my HAL file generated by pncconfig and i just inserted it into my custom.hal and removed it from my machine.hal
hm2_7i96.0.stepgen.01.position-cmd i've tried many different variations of the above and still cant seem to get it to work
Last edit: 08 Dec 2020 12:12 by tpmagda12.
- tpmagda12
08 Dec 2020 12:15 #191436
by tpmagda12
Replied by tpmagda12 on topic Correcting axis bend with custom component and HAL
I see this is a lot and maybe i should just boil it down to the following question
what is the difference between the following? I don't understand the difference between cmd and fb
hm2_7i96.0.stepgen.01.position-cmd Please Log in or Create an account to join the conversation.
- Thank you received: 5336
08 Dec 2020 12:25 - 08 Dec 2020 12:25 #191437
Replied by PCW on topic Correcting axis bend with custom component and HAL
joint.1.motor-pos-cmd is the position command from LinuxCNC (driven by gcode, MDI or jog commands)
joint.1.motor-pos-cmd is the feedback position from the hardware that tells LinuxCNC
how well the hardware is following the commanded position
BTW you should not run the hardware stepgen in position mode
(hm2_7i96.0.stepgen.0N.position-cmd should be unconnected)
pncconf will make a good velocity mode hardware stepgen hal file
you should use the as a starting point to your modifications
Last edit: 08 Dec 2020 12:25 by PCW.
The following user(s) said Thank You: tpmagda12
- tpmagda12
08 Dec 2020 18:58 - 08 Dec 2020 19:51 #191452
by tpmagda12
ok, so it should be connected to hm2_7i96.0.stepgen.0N.velocity-cmd
As far as i can tell this will be controlled via PID by passing the desired positional value to pid.N.command and then the PID controller would handle the rest via a 'positional loop' comparing the difference between the feedback and the commanded position. Because i am runner a stepper system without any encoder this feedback is actually coming from linuxcnc stepgens.
does that seem to make sense?
Last edit: 08 Dec 2020 19:51 by tpmagda12.
08 Dec 2020 19:43 #191457
The hm2_7i96.0.stepgen.0N.velocity-cmd pin should be
connected to the PID output.
The PID command is connected to joint.N.motor-pos-cmd
and the PID feedback is connected to hm2_7i96.0.stepgen.0N.position-fb
As I mentioned, pncconf creates these connections (and instantiates
the needed components), so you don't need to bother with any of this
level of detail
Note, it may be cleaner to insert your "fudge factor" by using the external
offsets feature, rather than modifying the position command directly.
level of detail
- tpmagda12
08 Dec 2020 19:59 - 08 Dec 2020 20:01 #191459
by tpmagda12
Thanks PCW, you've been a huge help.
i think the external offsets feature makes more sense after looking into it.
Last edit: 08 Dec 2020 20:01 by tpmagda12.
- tpmagda12
08 Dec 2020 20:13 - 08 Dec 2020 20:33 #191462
by tpmagda12
would something like this make sense if i were to just go with the custom.hal approach? basically delete the x-pos-cmd signal created by pncconf and just replacing it with my own.
#custom.hal
delsig x-pos-cmd # delete signal that is providing position command to pid.x.command
net x-pos-cmd-new joint.0.motor-pos-cmd => y-axis-compensation.x-in # reroute motor-pos-cmd to "fudge factor"
net x-pos-comp y-axis-compensation.x-out => pid.x.command # "fudge factor" becomes new commanded position
Last edit: 08 Dec 2020 20:33 by tpmagda12.
- tpmagda12
13 Dec 2020 21:08 - 13 Dec 2020 21:10 #191936
by tpmagda12
External offsets was the way to go, works like a charm.Thanks PCW for pointing me in the right direction!. If anyone stumbles across this with a similar question:
Create custom component with your parameters. axis.L.eoffset-counts requires an int(s32) data type so if you are working with anything more precise than 1 machine unit (inche or mm) you are going to have to scale it up and convert to an int(s32). this later will get scaled back down in your custom.hal. Below is an example of mine based off of the post here .
install custom component using halcompile
link it up to your custom.hal
and add OFFSET_AV_RATIO to your ini under [AXIS_L] to enable external offsets
and now she cuts dead straight!
component y_axis_compensation;
pin in float x-in;
pin in float y-in;
pin out s32 x-out;
variable float scale;
variable float m;
function Ycomp;
FUNCTION(Ycomp){
x_comp = - 0.00000000067940966640 * pow(y_in,6) + 0.00000009976544202068 * pow(y_in,5) - 0.00000530514086312159 * pow(y_in,4) + 0.00012255623616536600 * pow(y_in,3) - 0.00129152087662694000 * pow(y_in,2) + 0.00948807979075069000 * y_in + 0.00835436369018987000;
scale = 0.0001;
m = x_comp/scale;
x_out = (int)m;
}install custom component using halcompile
addf y-axis-compensation.Ycomp servo-thread
# Extenal Axis Offset
# requires INI: [AXIS_L] OFFSET_AV_RATIO = value (controls accel/vel for external offsets)
setp axis.x.eoffset-scale 0.0001
setp axis.x.eoffset-enable TRUE
net x-pos-comp y-axis-compensation.x-out => axis.x.eoffset-counts
[AXIS_X]
OFFSET_AV_RATIO = 0.1and now she cuts dead straight!
Last edit: 13 Dec 2020 21:10 by tpmagda12. Reason: Thanks to PCW
The following user(s) said Thank You: tommylight, rodw, Aciera
