W axis can't run to F word
- JesusAlos
14 Dec 2020 13:52 #191972
by JesusAlos
W axis can't run to F word was created by JesusAlos
Hi all.
I have a problem with this gcode sample:
G21 G17 G54 G64 P1 G90
F1000
S100
G1 X1682 W82 F3000
G1 W282 F3000
G1 X1714 W46 F1000
G1 X1682 W82 F3000
M30
I can't reach to understand why in the line "G1 X1714 W46 F1000" W goes to high speed 3600m/min and the velocity value on the axis show 488m/m.
I tried:
G1 X1714 W46 F400
and W don't exceed the 400m/min speed.
But If I try:
G1 X1714 W46 F500
W goes to max speed 3600m/min and the interpeter axis show vel. 488
Thank you.
F1000
S100
G1 X1682 W82 F3000
G1 W282 F3000
G1 X1714 W46 F1000
G1 X1682 W82 F3000
M30
I tried:
G1 X1714 W46 F400
But If I try:
G1 X1714 W46 F500
Thank you.
- Thank you received: 7505
27 Dec 2020 07:10 #193295
Replied by tommylight on topic W axis can't run to F word
Bump.
- JesusAlos
27 Dec 2020 12:49 #193304
by JesusAlos
Replied by JesusAlos on topic W axis can't run to F word
Hello.
What does Bump mean?
A bug?
Regards.
A bug?
Regards.
- Thank you received: 2177
27 Dec 2020 13:13 #193305
Replied by Aciera on topic W axis can't run to F word
Ha, no. Bump means Tommy wanted's to "bump" it back to the top of the list of topics to see if maybe somebody has an answer to your question otherwise it would just get buried under all the new stuff.
- anfänger
- Thank you received: 271
28 Dec 2020 04:06 #193345
by anfänger
Replied by anfänger on topic W axis can't run to F word
can you show your ini. I thing there is something wrong with the settings. And some details about the machine.
- TurBoss
- Thank you received: 81
31 Dec 2020 16:49 #193684
by TurBoss
Replied by TurBoss on topic W axis can't run to F word
Hello,
here is a config that can show the issue
when the line 3 is executed velocity seems uncontrollable
found w.ngc under nc_files
Time to create page: 0.103 seconds
