check_config: Unchecked: [KINS]KINEMATICS=rotarydeltakins
  • bkt
  • bkt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
28 Dec 2020 06:26 - 28 Dec 2020 06:27 #193355 by bkt
Sorry for these helps I need. I use for first time provided default retarydeltakins. Other time I use my kins versions, customized.
Now when I launch my configuration that uses the standard rotarydeltakins library, this very suspicious message appears on the terminal:
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/test/linuxcnc/configs/et-3ax'
Machine configuration file is 'cia402.ini'
check_config: Unchecked: [KINS]KINEMATICS=rotarydeltakins <--------
/*stranges messages, never see until now*/
Starting LinuxCNC...
Found file(REL): ./cia402.hal
Note: Using POSIX realtime
Does anyone know if I have to worry, or if there is something to change?
I add that I use mint for these tests.
bkt
Last edit: 28 Dec 2020 06:27 by bkt.
28 Dec 2020 07:06 #193359 by Aciera
seems perfectly normal output to me.
Are you worried about the "./cia402.hal"? I don't think an intelligence agency would infiltrate your machine controller and then use a file name like that.:)
The following user(s) said Thank You: bkt
  • bkt
  • Platinum Member
  • Platinum Member
28 Dec 2020 12:36 #193375 by bkt
:laugh: :laugh: :laugh:
www.can-cia.org/can-knowledge/canopen/cia402/
...... my concern was about "unchecked" .... because normally I use my abc_delta.so file and never see that .... i asked before running into unwanted errors.
bkt
29 Dec 2020 02:12 #193406 by Aciera
Ah, I think that pops up whenever you load a config that does not use trivkins.
code for that is in ./lib/hallib/check_config.tcl line 200
  • bkt
  • Platinum Member
  • Platinum Member
02 Jan 2021 05:20 #193828 by bkt
ok.
bkt
