millkins changed to compensate for y axis with axis skew
03 Jan 2021 16:57 - 03 Jan 2021 22:47 #193998 by Michael
I am attempting to correct misalignment between my X and Y axis. I have measured it along the Y axis moving from + to - as moving from 0 to +.004". Since I have my fixture plate and everything else aligned to the x axis I would like to use millkins.c to make the adjustments but as written it would correct the skew by compensating the x axis.
To change it to Y axis it appears that only a few lines need to be changed. Can anyone confirm this as being correct? Chnaged these two areas and commented # out the original lines:
#pos->tran.x = joints[0] + joints[1]*(*(haldata->skew));
pos->tran.x = joints[0];
#pos->tran.y = joints[1];
pos->tran.y = joints[1] + joints[0]*(*(haldata->skew));
#joints[0] = pos->tran.x - pos->tran.y*(*(haldata->skew));
joints[0] = pos->tran.x;
#joints[1] = pos->tran.y;
joints[1] = pos->tran.y - pos->tran.x*(*(haldata->skew));
#include "kinematics.h"
#ifdef RTAPI
#include "rtapi.h"      /* RTAPI realtime OS API */
#include "rtapi_app.h"      /* RTAPI realtime module decls */
#include "hal.h"
struct haldata {
    hal_float_t *skew;
} *haldata;
int kinematicsForward(const double *joints,
              EmcPose * pos,
              const KINEMATICS_FORWARD_FLAGS * fflags,
              KINEMATICS_INVERSE_FLAGS * iflags)
    pos->tran.z = joints[2];
    pos->a = joints[3];
    pos->b = joints[4];
    pos->c = joints[5];
    pos->u = joints[6];
    pos->v = joints[7];
    pos->w = joints[8];
    return 0;
int kinematicsInverse(const EmcPose * pos,
              double *joints,
              const KINEMATICS_INVERSE_FLAGS * iflags,
              KINEMATICS_FORWARD_FLAGS * fflags)
    joints[2] = pos->tran.z;
    joints[3] = pos->a;
    joints[4] = pos->b;
    joints[5] = pos->c;
    joints[6] = pos->u;
    joints[7] = pos->v;
    joints[8] = pos->w;
    return 0;
/* implemented for these kinematics as giving joints preference */
int kinematicsHome(EmcPose * world,
           double *joint,
    *fflags = 0;
    *iflags = 0;
    return kinematicsForward(joint, world, fflags, iflags);
KINEMATICS_TYPE kinematicsType()
    return KINEMATICS_IDENTITY;
EXPORT_SYMBOL(kinematicsType);
EXPORT_SYMBOL(kinematicsForward);
EXPORT_SYMBOL(kinematicsInverse);
MODULE_LICENSE("GPL");
int comp_id;
int rtapi_app_main(void) {
    int res = 0;
    comp_id = hal_init("millkins");
    if(comp_id < 0) return comp_id;
    do {
      haldata = hal_malloc(sizeof(struct haldata));
      if(!haldata) break;
      res = hal_pin_float_new("millkins.skew", HAL_IN, &(haldata->skew), comp_id);
      if (res < 0) break;
      hal_ready(comp_id);
      return 0;
    } while (0);
    hal_exit(comp_id);
    return comp_id;
void rtapi_app_exit(void)
  hal_exit(comp_id);
#endif
Last edit: 03 Jan 2021 22:47 by Michael.
07 Jan 2021 10:21 #194373 by andypugh
Yes, looks right to me.
